If there anyone interested in Yocto metal box then here is order form for 4th batch:
https://goo.gl/forms/8wEerMI7phO2h4Nu1
I made some improvements there:
- enclosures have installed spacers, so the front panel is free from screws, so you do not need any other parts to mount a PCB inside the case
- they are compatible with gihaume wood sides (viewtopic.php?f=16&t=420)
- enclosures have lower front so ther are "slimmer"
When there will be enough interested people then i will send you payment request and make an order in manufacture.
If you have any questions pleas write me: kacperpawluk@gmail.com
PS. Please don't comment this topic if you don't have to do it - it will help for others forum users to find informations easier.
[resize=800]https://lh3.googleusercontent.com/vUHVk ... xI8mSJ1KWA[/resize]
YOCTO ENCLOSURES - 4th batch
Sorry, but no "slimmer version" this round? =)
It will be "slimmer" version this round
Yes, I am interested.
Thanks for sharing.
Thanks for sharing.
registered for 4th batch
For all interested people - i will close ordering for this batch at 12th of September.
with the lower front does this mean it is different from the nava enclosure?
the same as nava enclosure.
hey kacperpawluk,
im building the yocto right now, is it safe to solder the step buttons right away, or would you recommend to wait for the box? and did you raise the step buttons with anything or did you put them on as is ?
thanks
thanks
you can solder everything right now and don't need to rise pushbuttons.
