starting a build - some newbie questions about the project
  • Bearing in mind the amount of build issues that are covered in this forum and elsewhere. I would definitely advise testing each component before you insert these. But it is better that your parts come from mouser as these will generally be more reliable than the component kits supplied with the original yocto offerings. Some parts are very close to each other so fine tip soulder iron may work better for you however ymmv. Lastly don't rely on this forum as many issues reported here go unanswered I imagine due to a focus shift onto the 909 project. Better to post on muffwigglers diy section as you will reach a wider pool of knowledge regarding audio circuits.
  • Cool thanks, im on MW too (mostly in the 3trins threads) so will check it for any Yocto info.
    I've scanned through some issues and notes and see that some guys recommend doing the noise mod.
    Will get some finer tips for the iron since that is pretty cheap. I think I am pretty much over the idea of doing an internal PSU as well - i don't mind having to carry around another adapter, and thankfully its a pretty common one. Will check some old threads here about it though since I have a nagging feeling that someone did mention that it improved their sound quality (while the nava case thread has E-lick guy saying a bit of the opposite).
    Will try to answer my own questions just for the sake of the community knowledge in case other people have these silly questions but are too afraid to ask hehe.
  • sockets: iirc the BOM only included a 40-pin socket for the atmega, and a 8-pin socket for the EEPROM
    i counted the remaining ICs, ordered these additional sockets:
    16-pin, 10: 571-1-2199298-4
    14-pin, 4: 571-1-2199298-3
    8-pin, 20: 571-1-2199298-2
    i may have rounded them up cuz i didn't mind having some spares
    i also used machined SIL sockets for the BA6110 but i didn't order them from mouser (i had a bunch already from a local shop)
    power: my yocto is running with internal power supply with a blue box-shaped transformer
    this makes things serious, because inside you're dealing with 220V (or whatever your mains is) and i'm highly respected by that..
    it has to be done properly in order to be safe, you don't want to get shocked, and you also don't want to fry some component(s) of the yocto
    case: having the case before you begin is a good idea
    in my case, i'm using the internal power supply mod, so it was good to have the case beforehand so i can have an idea how to do it in terms of cabling, the case is also made out of metal which is a very good idea when you're introducing mains into the thing, and it has to be earthed for safety (which is something i think i'm still not finished with, i'm learning about grounding and earthing because it's complicated)
    IMO there are some components you really better NOT mount before you have the actual case, that's the components which will come thru the case, like the switches/buttons, etc.. there's not much you can do about the pots (and they are usually not an issue) but if it turns out that your buttons are sitting too low on the front panel, or too high - you can compensate (in my case, i did, they were too low)
    so i highly recommend mounting the PCB onto the case and inspecting how it looks, before soldering these kinds of components
    measuring each component: i did that when i built my x0xb0x, yes.. out of a strip of 10K resistors - i measured every single one of them.. well that was stupid, i know
    for the yocto, i did the following:
    1) sort the bags of passive components into capacitors and resistors
    2) sort the resistors into 3 piles - "below 1K", "1K to 100K" and "above 100K"
    3) sort the capacitors into 2 piles - "below 1uF" and "above 1uF"
    perhaps it would have been a good idea to split them further below 0.1uF but i didn't cuz of lack of containers where to put them
    then as i began building the thing, when i had to take out a component from the bags, say a resistor - i'd check the value very carefully, i'd also measure one from the bag to make sure it's not off (the label on some bags was hard to read) and finally, when i'm done - i wrote the position(s) where i soldered resistors onto the empty white space of the bag
    so, i checked very well, but i did not measure each and every resistor out of a whole strip
    tuning: i don't have a scope, only a cheap multimeter
    i followed the build instructions till the toms section i think, somewhere at that point was where i could no longer finish the next section because i did not have 22nF capacitors (which i was waiting to come from ebay)
    so i decided to keep building with the components i had, but i skipped the tests since i was not sure if it was okay to power the board with those capacitors missing from the circuit
    at the end, it worked, i didn't tune the noise as per the manual because my multimeter's lowest VAC setting is 200, and there's not much precision there.. i tuned that by "taste", i tuned the cowbell by ear, then i measured the frequencies of the two oscillators and figured that mine were too low and i didn't had enough range, so i replaced two resistors as suggested by.. i forgot where, and then i could tune them (i used a 808cowbell sample from somewhere which i had measured beforehand, i just played it repeatedly from the DAW and played the yocto cowbell repeatedly too while adjusting the trimpots)
    FW update: i haven't done this, but i think they have put a bootloader which works via "MIDI IN" .. so you'd need a computer with a MIDI-OUT and a program which can send "SYSEX" (there are such apps available easily)
    iron: this kit has just thru-hole components, so it's easy to build, the only issue is in some crowded areas (and there are such quite a bunch) .. a sharp tip is what i used
    i also used another iron with a tip which used to be sharp but isn't, used it for desoldering the step buttons (that was due to a dumb mistake which cost me a whole day and tears to fix)
    temperature: yes, the surrounding temperature does cause changes in the behavior of components/circuits, but this question is above my head
    i can only say that, for circuits where tuning matters (like oscillators) the designers would put compensating circuits
    i don't think the 808 has them, the yocto doesn't appear to have added additional stuff into the analog circuit
    you should tune the thing while it's in "room" temperature.. don't worry about it too much
    if you want perfect operation - get a digital 808 emulation ;)
    trimpots: i wouldn't put glue or anything on them, they are usually "tight" enough
    you'll get an idea when you twist them with the screwdriver
    updates: my impression is that most of the BOM updates by users was not to improve sound but because from time to time the BOM because impossible to order due to this or that component gone out of stock, a lot of the components are passive and there are almost always alternatives, so the folks simply find a substitute component from another brand and update the BOM so they can order it
    my mouser package came with a few film capacitors replaced with philips ones, which was not good, the philips ones were wide while the PCB design was meant for tall ones, so i had to buy additional caps from ebay
  • thanks a lot!
  • Huge thanks guys for the added confidence - finally finished it over last winter and very happy with it!
  • Antto,
    Thanks for the detailed post. I'm in the early stages of getting all the bits together (waiting for a PCB set to come back in stock first) but it's good to know this sort of detail beforehand.
  • i also wish some such information to be available in the actual build instructions or so
    but maybe that sort of thing is better to be arranged by the community in some form similar to a wiki
    but it's partially my own fault that i did not research the forums before picking up the yocto, so the whole thing was foggy to me
  • Activate your Discover credit card instantly with the official discover.com/activate site. Go to discover.com/activate to complete Discover card activation and unlock rewards. Manage your Discover account and activate your card easily at discover.com/activate. Start shopping today by activating your Discover card online at discover.com/activate.
  • Quick UHC Member ID Activation – Ensure your UnitedHealthcare insurance is ready to use by activating your card at Activate.uhc.com. UnitedHealthcare Online Activation – Simply visit Activate.uhc.com, enter your details, and get your UHC card activated instantly. Step-by-Step UHC Activation – Follow the on-screen instructions at Activate.uhc.com to activate your UnitedHealthcare card effortlessly. New UHC Card Activation – Just received your UHC card? Go to Activate.uhc.com to activate it and access your healthcare plan. Secure UHC Card Activation – Activate your UnitedHealthcare insurance card at Activate.uhc.com and start managing your benefits securely.
