Hello!
Finished my Nava! Everything works great just buzz in BD section
I made sample from individual BD output, link below.
This is ok?
https://www.dropbox.com/s/66qet15s424xo ... e.wav?dl=0
[solved] Bass Drum BUZZZ
Have you checked that your cables are not "broken"?
Many of mine have fell off the IO board during testing without me noticing and wondering what is broke this time just to find that a cable has fell off.
Gonna swap all of them with molex connectors instead.
All cables new and checked.
Thank you for advice
Nobody?
Is the sound only when using individual output? or also on main out?
Checked all solder joint? Checked that all components are the right value at the right place?
Same buzz in individual and main output
Did you find a solution already? I have exactly the same buzz at the bassdrum
not yet.
Im building right now tr9090, want use it as reference for find buzz source.
ok, I'll check the bassdrum of my nava this weekend, if I find the issue I'll let you know.
It's ironic that you guys are having the buzz on the Nava's bass drum since that's exactly what I'm having an issue with on my Yocto. I'm getting ready to build the Nava so maybe when one of us figures this out I'll be able to solve the issue if it happens to my Nava too. Good luck!
