Here is the last version of Nava v1.0 firmware
Changelog:
v1.028beta:
-Should fix encoder issue v1.028 by zabox :
Fixed:
- Digital instruments: velocity changes in midi play, tap mode and in combination with total accent
- Led flickering
- Various minor improvements
Code: Select all
New features:
	- Flam
	- Low latency expander mode
How to use flam (BD, SD, Toms):
	- Press "Instrument Select" + both instrument buttons to select flam
   	  (indicated by a lower case letter, e.g. bD, sD, ...)
	- Hold "Shuffle / Flam" and press step button 9-16 to select the inverval (20ms-48ms)
How to use expander mode:
 	- Set sync to "EXP" to enter expander mode
	- Press "Guide" to show triggers
	- Press "Mute" to enter mute mode
	- Press "Bank" to enter gate mode and select instruments like in mute mode
         (gate cuts the sound at a midi note off message)
Notes:
	- Gate has almost no effect on SD and Toms
	- BD gate increases when turning the decay pot counter clockwise
	- Trig-1 is selectable in both mute and gate modesFixed:
- Pattern change bug in slave mode
- Hihat cuts in tap mode
- Short trig-1 pulse when played over midi Beta version with Flam. Read this carefully v1.026 by zabox :
Fixed:
- Mux issue with external trigger
- Mux settling times
- External trigger length drop
- Din clock phase
- Midi clock out lag
- Pattern group bugs in step write and pattern play mode
- Shuffle update in tap mode
- Crash when deleting more than the last track position
- Double midi real time messages on midi out in slave mode
- Various other bugfixes
Updates:
- Instruments mute while holding clear
- In tap mode: hold clear + instrument to delete steps
- Seperate CH/OH mute (can be set to combined mute again in global settings page 2)
- Pattern numbers match the step button numbers
- Track and external instrument positions start at 1 v1.025:
-Fixed MIDI play mode
-Pressed Pattern play button alternate access to Step and Play mode (no need to press shift again)
-Pattern Group incremente in MUTE mode (fixed)
-Improve Tap mode HH
-Various bug fixed v1.024:
-Improve accent response
WORK ONLY WITH THE MUX/SH BOARD MODS
-Trig out length is 10ms now v1.023:
-No more HH ticks background noise
-Improved velocity on all instrument
You should replace C89 and C163 by 10nF (Build manual and Mouser BOM updated)
 -Clear pattern now set minimum velocity that increase velocity response
-CH Tap Mode bug fixed
-Improve Slave sync when pattern save/change (Please Keep up to date on improving sync cause we do not have this issue with our Midi interface) v1.022:
-Fix OH select Bug v1.021:
-Tap Bug fixed
-Velocity HH can be saved
-OH Velocity and Total ACC conflict solved
-Improved BD, SD and HC velocity response
-RX Midi channel issue solved
-Buttons functions improved
-Sync test in slave mode with a TR505 and with Ableton and Midi interface.
Sync with hardware is perfect but Nava loose some clock signal when sync with a software thru a Midi interface.
Replace R365 value by 1K and R314 value by 4K7 to increase Midi signal should solve this issue v1.020:
-Fixed CH and OH bug in MIDI play
-Add a config page that allow you to set the sequencer pattern change SYNC or FREE: -Push Tempo button twice while holding SHIFT button to access to the second config page. Use the encoder to select "pCH" (pattern change) SYN => SYNC or FRE => FREE. push the enter button to store new sequencer setup v1.019:
-Fixed Middle Tom low volume
-Now respond to Midi note ON velocity 0 message as a Midi note OFF message v1.018:
-Fixed Total Accent issue on crash and ride instruments v1.017:
-Original version Best regards,
