this is work in progress as I build...
- 100pf ceramic cap missing
currently at the BD. Mouser BOM lists 1 x 100pF ceramic. Noise needs one C47, BD also at C4
- MISO and MOSI switched at the ISP header
My build log - missing parts, questions and suggestions
- pot labeling confusing (uncommon)
is a A-100k pot = 100.000 ohm = A1 04 ? the little marking on the bottom?
In fact you need 5x 100pF capacitors. Mouser BOM updated, thank you for this advice.comboy wrote: - 100pf ceramic cap missing
Yes it is.comboy wrote: is a A-100k pot = 100.000 ohm = A1 04 ? the little marking on the bottom?
1 x 20k missing.
I have only 4 x 20k from the mouser BOM
1 x 68k missing
only 2 are in the BOM, we need 3 for the 3 toms.
it's getting annoying
another thing.
why are no 0.1% 10k resistors used for the R2R DACs when all other values are 0.1% resistors?
Would save one from hand selecting the normal 1% 10k resistors with a multimeter.
Mouser BOM updatedcomboy wrote:another thing.
I have plenty of 1k resistors left, but am missing nearly all 1k2 resistors from the sequencer.
havn't counted them yet but my guess is there are 1k instead of 1k2 resistors in the BOM.
1 x 100k missing
0.0022uF missing.
3 on the bom.
bd needs 1, sd needs 3
I feel like the first person to actually test the BOM :-/
3 on the bom.
