lol, it seems like every time a fix one issue another pops up!
So after fixing the low tom due to a bad opamp, I am near completion of the build and everything makes the correct sound. However, when I have the master volume all the way up some sounds start to clip...the toms mostly and mainly when it is a high pitched . This is a new problem that was not there previously. Any yocto/electronics gurus out there have any idea why this would just start up when it wasn't happening previously?
				output clips when fully cw
Do you have the same issue on the individual outs?
				Yes I get it regardless of the output I use. I have a suspicion it has something to do with the accent because when I turn it down it goes away. Come to think of it though, I can also make it go away if I back off the master as well. ???
