Hi, Just got my kit and assembled the i/o board portion of the ps.
I get reading within spec on +15v and +5v but on -15v I am reading -17.2v(measured with two different meters to be sure)
Doubled checked all components going in, before  and after solder.
Any suggestions? or should I continue with the build?
thanks for any help
				Power supply voltage:trouble shoot
Dear Ebbflo,
The negative regulator needs a slight load to begin regulating. Use a 2k7 ohm resistor between ground and -15v to check -15v.
Thanks,
That is what I assumed but wanted to make sure. I am the guy that has the incomplete kit. I am sending pics now.
Best,
Neil
Best,
Neil
Hmm... Well I tried the resistor and it really did not knock it down by much. I went a head and built the noise and got the same readings on the "green dot" on u24. The trim pot will not trim down to 130mv after u24 soldered in either...
I've built kits before that behaved similarly and ended up fine when everything was in place but never built the yocto...
Thanks
Thanks
Hey Ebbflo,ebbflo wrote:I went a head and built the noise and got the same readings on the "green dot" on u24. The trim pot will not trim down to 130mv after u24 soldered in either...
Have a browse of this thread viewtopic.php?f=16&t=155 there is a lot of info about how to get the correct noise trimmer voltage.
Thanks, I have some 100k trimmers, so I think I will use that for the time.lfo2vco wrote: viewtopic.php?f=16&t=155
Atleast for me the 2,7k ohm resistor did the trick (Got -15.04V and +15.05 and +5.04). I have good 15 VAC 1,3A AC/AC Adapter: http://www.mascot.no/admin/common/getim ... ileID=1232e-licktronic wrote:Dear Ebbflo,
																																								lfo2vco, your trimmer trick worked. I will probably just leave it in place...
thanks again,
				thanks again,
When I measure voltage from power supply I get +15.05V, -16.30V and +5.04V and with 2,7k resistor i get -15.04 from the negative side.
Question is that is it ok that when I measure voltage from NOISE negative pin, I get the same -16.30V? Is the situation same that the regulator does not have enough load to start regulating?
Glad it helped. I decided to leave well alone and left the trimmer in place.ebbflo wrote:lfo2vco, your trimmer trick worked. I will probably just leave it in place...
