Happy new Nava owner here.
I'd like to suggest an addition for the next firmware update.
Direct pattern change, as implemented in the Analog RYTM, is the option to have the pattern change instantaneously rather than waiting until the end of the bar.
I haven't seen this feature on many other machines, but if it is possible to implement this, it is without a doubt the most musically useful feature I've ever encountered on a sequencer.
It allows the user to have several more busy patterns which can be 'punched' into for as little as one or two steps, at any point, before then punching back into the main pattern or whichever pattern you choose. It is, in my opinion, the most intuitive way of achieving fills, and would take this machine to another level!
I hope this makes sense. And I guess, if you were to implement this, it would also be nice to be able to choose from some other pattern change quantisation(?) behaviours. Choices could range from: The traditional "change at the end of the bar", or "change at the next 1/4 note", or "change at the next 1/8 note". But most importantly.. "Direct Change" Ie. Change NOW!
I would love to see this feature implemented if the hardware will allow for such a thing..
				Direct Pattern Change!
+1 for this. It would be a brucey bonus.
				Hello,
I'm an ordinary user so I don't have deep knowledge of the Nava system but a few ideas/remarks.
I believe that the flashing button means you're in pattern step edit mode, not play mode.
The error sounds a little bit like there's something wrong with a step counter, maybe you should check soldering of logic IC:s?
It sounds a little bit like you're in chain mode also but maybe that's me misunderstanding your description.
Also, the 909-system is not quite like the Nava system. A lot of functionality is different so the manual for 909 is not of so big use.
brother printer drivers  are software programs that allow your computer or device to communicate with and control Brother printers for smooth printing and scanning operations.
software programs that enable smooth communication between your computer or mobile device and the Brother printer, ensuring accurate printing, scanning, and other functions is known asbrother printer drivers
software that serve as a translator between your brother printer drivers and your computer or device, allowing printing, scanning or other functions to work properly.
brother printer drivers are essential software that enable smooth communication between your computer or device and a Brother printer, ensuring accurate print commands, compatibility, and access to advanced features like scanning, wireless printing, and troubleshooting support.
brother printer drivers are software that enable communication between your Brother printer and computer for smooth printing and scanning.
brother printer drivers  are software translators that let Brother printers/labellers/scanning/sewing machines understand the data your computer sends (for documents, images, etc.) so they print/scan correctly.
brother printer drivers are software programs that allow your computer or device to communicate with Brother printers, ensuring smooth printing, scanning, and connectivity functions.
Software that acts as a translator between yourbrother printer drivers and your computer or device, enabling smooth printing, scanning, and other functions.
brother printer drivers are software that connect your printer to your computer, ensuring proper functionality and performance.
Installing Epson Printer Drivers  properly is the main part to getting your Epson printer working without issues. If  you're using a Windows PC or a Mac, this guide teaches you through every step clearly and simply to download and install Epson Printer Drivers.
Epson Printer Drivers are essential software programs that enable communication between your computer or device and the Epson printer, ensuring smooth operation of functions like printing, scanning, and advanced settings.
Epson Printer Drivers are software that connect your printer to your computer, enabling printing, scanning, and other functions.
Epson Printer Drivers are software components that let your computer communicate with an Epson printer, translating document data into a format the printer can understand.
Before you begin installing Epson Printer Drivers software, you must first connect the printer to the network so that it can be used from a computer. Simply follow the instructions in the manual to set up the printer and connect it to the network.
Epson Printer Drivers  are software that let your computer communicate with Epson printers, managing print jobs and printer settings.
				Homedepot.com/mycard  is the online portal to manage your Home Depot credit card account.
At Homedepot.com/mycard , users can securely access their credit card details anytime.
Homedepot.com/mycard is the online portal where Home Depot credit card holders can manage their accounts, pay bills, and track purchases.
Lowes.syf.com/activate is the online page to activate your Lowe’s credit card online.
It allows Lowes.syf.com/activate cardholders to securely enable their new card for use.
The site provides a quick way to activate and manage your Lowes.syf.com/activate account.
Lowes.syf.com/activate ensures your card is ready for purchases and rewards.
It’s the secure portal for activating Lowes.syf.com/activate issued by Synchrony Bank.
Cardholders must complete activation at Lowes.syf.com/getstarted  before using their card.
Activating your Lowes.syf.com/activate online is simple through Lowes.syf.com/activate.
Lowes.syf.com/activate is designed for safe and convenient card activation.
