Hello fellow Yocto makers and sellers,
First of all I have little to none experience in electronics. I once made a radio when I was very young and the Yocto is my second project ever. Without the very good Yocto building manual it would not have worked. Thanks for providing the manual.
Problem 1:
When in pattern-mode (or edit track mode) my steps buttons will switch to button 8 (without touching). I haven't tried other modes. Clear track workes fine and when I make a track the Yocto saves it just normal.
Problem 2:
Playing the original track 1 in pattern-mode 1-16 will let the leds light-up, but 17-32 will not light-up. The track keeps playing fine.
Problem 3:
When I have pressed MUTE all works fine, but when I want to leave the Mute mode using SHIFT all goes quiet. The leds keep lighting-up.
All the sounds sound 808-ish. No problem there! Even the cow-bell sounds good, just like I want it to sound. I only would love to make my Low Tom sound much lower, but that is personal.
I hope you can help me.
Shiva
				Something wrong with my sequencer
Dear Shiva niet,
Could you post a video of your problems it will be easier to understand what's happen with the sequencer.
Problem 1:
http://we.tl/7hQyxnh2UT
Problem 2:
For now not a problem no more.
Problem 3:
After I push SHIFT and leave MUTE MODE there is one run 1x16 with sound. The second run is without sound on every pattern.
http://we.tl/cUy7oe4QnX
I hope this helps.
Greetings,
Shiva
Problem 2:
Problem 3:
I hope this helps.
Greetings,
Shiva
Dear Shiva niet,
Try to reload the firmware because it doesn't looks like a hardware problem.You can find Sysex file here
so I need to do the following(?)
Here is the next challenge is I do not have a midi interface. Will any interface work even the cheap ones?
For exsample M-Audio MIDI Sport 2x2.
				All this is with a midi-connection, am I right?To uplaod the firmware you have to proceed like that:
-Turn Off your Yocto
-Push step button 1, 3 and 5 together
-Turn On Yocto while holding threes buttons.
-Leds will blink two times
-Then send Sysex via MidiOX or an other MIDI sysex sender.
-Leds will show you Upload progress.
Yes.e-licktronic wrote:All this is with a midi-connection, am I right?
Normally yes.e-licktronic wrote:Here is the next challenge is I do not have a midi interface. Will any interface work even the cheap ones?
Hello e-lictronic,
I have uploaded the firmware. Question: while uploading do the leds only blink up to S8 and when finnished all leds (S1 till S16) blink twice? If yes all went well. Does it matter in which position the Mode Selector is?
But after a couple of minutes playing with my Yocto I get the same problems again. And in pattern mode when pushing S7 it goes direct to S8. S6 and S9 do not have this problem.
I really hope you can help solve this problem.
Yes it's right .Shiva Niet wrote:while uploading do the leds only blink up to S8 and when finnished all leds (S1 till S16) blink twice?
Try to upload firmware again and test all Yocto function because it's very strange that everything worked fine then stop working. Did you check all solders ? i think you've got a short cut somewhere around S8.
okay, the uploading (again) went well. But still the problem. Not in the beginning, but after a while. I will time it today.
All step buttons S1 up to S16 have the same value when testing with my multimeter. S17 and S18 do not have the same values. I de-soldered S8 and S18 both have same value. I will send my drawing tonight.
Sometimes in Mute mode S8 flickers before muting/un-muting.
Just running a pattern and pushing Shift gives a total mute.
All the solders look fine. Here are the bridges I have found: R129+424, C36*+C43*, D7*+D8*, C137+R?(BrownGreenOrangeGold) and C73+R215 (D52+C39 have no solder bridge. I really do my best when soldering.)
OH, CY, CP/MA and Trig-2 look like they have been very warm. I will send picture tonight.
Can I have one of the ICs overheated when soldering?
DUH? Now you can shoot me!
I turned the Yocto on and made a coffee and took a sigaret. I began playing after +/- 15 minutes.
Everything in Pattern, Pt edit, Mute mode and using Shift works(?). Last half hour (or longer) I have been playing and making patterns. Pattern 1 and using different banks. Mute mode playing with S7 and S8. Up till now no problems.
I will be testing more today.
