My Hi Tom seems to be coming and going!
The fault is the Hi Tom is intermittently only getting the White Noise component (Hi Conga seems fine).
Historically when I first powered up the Yocto the Hi Tom was fine, then it went wrong. I reflowed all the solder joints and it came back.
It was OK through my final tests and tweaks, prior to putting the boards in the case.
Once I had put the boards in the enclosure it went wrong again, so I thought it might be a faulty jumper or that I had stressed a solder joint.
However it came back of its own accord and seemed fine for a session.
Next time I turned on the Yocto it was gone again.
Where should I put my Multimeter to check the trigger?
What components could be the culprits and can I check them prior to replacement?
Thanks in advance for your assistance, otherwise I am having a great time with the Yocto
