SquareSeq vX.0 by e-licktronic
Here we talk about e-licktronic projects (hardware, software) like SquareSeq, Ablickton...
  • I have just purchased the SquareSeq. While most functions appear to work correctly, all the LEDs on all 3 boards stay on permanently. How can this be rectified?
    Additionally, are there any more comprehensive instructions for using it?
    Thanks
    John
  • Dear johnevan51,
    Please could you check Lickogic connection. Are you sure you connect OUT to IN.
  • Yes, I have the correct OUT-IN connection with the cables. The FUNCTION buttons on Dilicktal board 1 are producing the correct responses on the LCD, and the buttons on Dilicktal boards 2 and 3 are also producing the correct inputs on the LCD. I can run through all the menus on the LCD. Given that the buttons are all working, I must have it connected correctly! However, all the LEDs remain on permanently.
  • Can you try to switch cablick16 maybe you 've got a faulty cable
  • I made a simple case for the Sequencer... just attached the EPS File for Lasercutting the Case.
    Material schould be 3mm thick, and screws are all M3 10mm.
    Just went back from Lasercutting the prototype and it worked. - Due to Problems with the PPI (Coreldraw uses 96ppi, inkscape 90) - I had some Size related troubles... Verify the size of the objects ! It should be : 176mm x 76mm x 186mm (Outer Dimension)
    have fun :-)
    A simple Case for the Sequencer. 96ppi EPS Format.
    Downloaded 6417 times
  • this sequencer can work with the mb 9090 tr 909 clone?
  • Dear Tiz,
    Of course it could work with any analog drum module with some adds.
  • Hi,
    I've just received my SquareSeq, but I'm having the same all-led-lit problem previously stated here.
    Hardware assembly should be ok as both Midilickuino and Dilicktal test sketches work correctly.
    SquareSeq shows correct info on the LCD and buttons work as they should, but the leds are all lit.
    Would be possible to have an updated SquareSeq firmware using the latest SRIO lib, as used in the Ablickton?
    Thank you.
    Regards,
    Soulomon
  • Dear soulomon,
    I just tried SquareSeq v1.1 without any problem.
    What kind of Arduino board do you use ? Duemilanova, Uno... ?
    What's your Arduino version ?
    Are you sure that Dilicktals are connected in the right way ? IN to OUT.
