IC3 4049N hex inverting buffer
  • Hello
    All CD4049U should work.
  • Easily set up your Vizio Smart TV or soundbar by visiting vizio.com/setup and follow simple on-screen instructions to connect your device.
    Go to vizio.com/setup to activate and configure your Vizio Smart TV or soundbar for the best streaming and entertainment experience.
    Visit vizio.com/setup to quickly connect, register, and personalize your Vizio Smart TV or home entertainment system.
    Set up your Vizio device online through vizio.com/setup. Activate your TV or soundbar and enjoy high-quality streaming with smart features at your fingertips.
    Set up and activate your Vizio Smart TV at vizio.com/setup in just minutes.
  • Visit vizio.com/setup for a simple and guided setup process. Whether it’s a Smart TV or soundbar, get connected in minutes and start watching.
    Easily configure your Vizio device online at vizio.com/setup
    At vizio.com/setup, you can register and set up your Vizio device quickly. Enjoy seamless entertainment with access to built-in apps, movies, and shows.
    Easily configure your Vizio Smart TV or home theater system at vizio.com/setup. Connect your device, activate smart features, and enjoy unlimited streaming.
    Complete your Vizio TV setup at vizio.com/setup and start streaming instantly.
  • Go to vizio.com/setup to complete your Vizio device setup easily.
    Head over to vizio.com/setup to activate and connect your Vizio Smart TV or soundbar. Follow easy step-by-step instructions to unlock smart apps and streaming.
    vizio.com/setup makes it easy to connect your Smart TV or soundbar.
    Activate your Vizio device in minutes with vizio.com/setup
  • Seamlessly set up your Vizio home entertainment system at vizio.com/setup
    Go to vizio.com/setup for quick activation and device registration.
    Set up Vizio SmartCast devices easily at vizio.com/setup
    Enjoy hassle-free setup for your Vizio TV at vizio.com/setup
    Set up your Vizio Smart TV or soundbar easily at vizio.com/setup.
  • Visit vizio.com/setup to quickly connect your Vizio Smart TV or soundbar. Follow guided instructions to register your device and enjoy endless streaming.
    At vizio.com/setup, you can set up, activate, and personalize your Vizio Smart TV or soundbar. Unlock access to apps, streaming services, and smart features.
    Easily configure your Vizio entertainment system at vizio.com/setup. From Wi-Fi connection to app activation, complete your setup in just a few clicks.
    vizio.com/setup helps you get your Smart TV or soundbar ready for use. Start enjoying your favorite shows, apps, and movies with a seamless setup process.
    Go to vizio.com/setup to register and activate your device. Whether it’s a TV or soundbar, enjoy fast setup and premium entertainment at home.
  • Set up your Vizio SmartCast TV or soundbar online at vizio.com/setup. Connect, register, and begin streaming with smart features designed for you.
    Activate and enjoy your Vizio Smart TV at vizio.com/setup.
    vizio.com/setup – the easiest way to connect your Smart TV or soundbar.
    Start streaming in minutes by setting up your Vizio device at vizio.com/setup.
    Visit vizio.com/setup to unlock apps and features on your Vizio TV.
  • Step-by-step guide to restore your Vizio TV at vizio.com/setup to factory defaults for smooth performance.
    Troubleshoot at vizio.com/setup why your Vizio Smart TV won’t turn on with quick fixes, expert tips, and simple steps to get it working again.
    Easily activate your Vizio Smart TV with vizio.com/setup. Connect to Wi-Fi, register your device, and start enjoying smart apps and entertainment instantly.
    Visit vizio.com/setup to personalize and configure your Vizio device. Whether it’s a Smart TV or soundbar, you’ll be ready to stream in just minutes.
    Make your Vizio setup simple at vizio.com/setup. Whether connecting a TV or soundbar, follow the quick guide to start streaming right away.
  • vizio.com/setup provides a quick way to set up and register your device. Activate your SmartCast TV or soundbar and access built-in apps, movies, and shows.
    Go to vizio.com/setup to easily connect and activate your Vizio Smart TV or soundbar. Complete setup in just a few steps and enjoy unlimited streaming.
    Set up your Vizio entertainment system online at vizio.com/setup. From Wi-Fi connection to SmartCast activation, everything is made simple and hassle-free.
    vizio.com/setup helps you link your TV to Wi-Fi and streaming apps instantly.
