Hi guys...I brought a nava already assembled and I'm experiencing a problem with the kick drum
The volume is way to much low compared to all the others instruments.
Way too low....
I'm having problem while producing my music now.
Cuz is way too low the volume of the bass drum and I'm obligate to low all the other istruments volumes in way to get a nice mix of all the drums parts.
And Even not so nice mix...
Do you guys can advise me a fix? Hardwere problem?software problem?
Tnx everybody
LOW BASS DRUM VOLUME
At the moment I either balence everything around the kick or mostly I send the kick to its own channel in the mixer. Hopefully this will be fixed in the next firmware update.
Hi there,
Any news on the low kick drum volume issue resolution ?
No. Nothing...I'm glad that is not just me,I was even an other post about instruments volumes.
Hope we can fix.
I hate that the kick is so low.
Hope we can fix.
BD should be on separate input on mixer, always.
I'm pretty sure this general common statement is specifically due do the TR-909's Master Out's being filtered by those wrong value capacitors and making the BD very obviously sound thinner.lukep_gdansk wrote:BD should be on separate input on mixer, always.
Just change your capacitors and don't worry, your mixer has nothing more magical than your groovebox in its mixing section.
Hi Gihaume - which capacitors did you change and to what new value?gihaume wrote:I'm pretty sure this general common statement is specifically due do the TR-909's Master Out's being filtered by those wrong value capacitors and making the BD very obviously sound thinner.lukep_gdansk wrote:BD should be on separate input on mixer, always.
I'm experiencing the same issue and don't really want to separate BD output only for this reason...
Thanks,
F.
Change C153/ C154 from 1uf to 10uf
Danke!KlangGenerator wrote:Change C153/ C154 from 1uf to 10uf
F.
Thank you for sharing. It's just the right time for me because I'm also having a similar problem.
