Hello,
Unfortunately the SNAPPY potentiometer of my snare drum (Potentiometer (B103) / VR9 /10K(B)) is broken (functional but the shaft is loose). Do you know where I can find a spare?
Greetings
				Spare part for the SNAPPY potentiometer
https://www.mouser.de/ProductDetail/Bou ... uWlwC80Q==FLOz wrote:Hello,
Greetings
Be aware that the D-shaft doesn't go all the way down to the body and needs to be filed. Otherwise it's an identical replacement.
Thanks for your fast reply.
But it seems that the lead spacing doesn't match between both potentiometers:
- The one on mouser has 5mm between pin 1 and 3 (standard lead spacing of 0.1inch).
- The one on the yocto has about 7,5mm between pin 1 and 3. And I don't find anything matching on the web (mouser, tayda, reichelt...).
I think I found the correct one: Bourns PDB12-H4251-103BF
https://www.mouser.de/ProductDetail/Bou ... mV5DwNKA==
