The push encoder is not working. I cannot tap tempo or unmute all tracks, etc. The dial, however, works properly.
Which components should I be checking?
Push encoder not functioning
Dear effegee,
Please check R48 and encoder solder
I opened up the enclosure and discovered that I hadn't soldered two pins of the encoder. Easy fix! Now it works. (I'm having so much fun with the 808 grooves!
