Dear Diyer,
If the Rimshot is lower than the clave change R324 value by 100K instead of 220K.
Rimshot lower than Clave problem
What do you mean by "lower"? I don't understand.
Sorry for my bad english,
I mean less volume than the Clave.
Hey! I did what you said for the Rimshot but the volume is still lower than the clave one!
Should I change R324 by a lower value?
Thanks,
Regards
Thanks,
Regards
Dear kluber,
Are you sure all rimshot components are in the right place ?
If this the case try a lower value like 56k or use a trimmer to find the right R324 value.
Could you post sample?
Well You were right indeed!
2 capas were inverted! (C126 & C26)
Everything work fine!
Thanks for all the support!
And I wish all the best to E-licktronic!
