Hi Vincent,
Issue with level of ACCENT_BD signal with vs. without accent (not total accent):
- TR909: the amplitude of the ENV2 without accent is half of the amplitude of the ENV2 with accent
- Nava: the amplitude of the ENV2 without accent is 2/3 of the amplitude of the ENV2 with accent
Would it be possible to align it in the next firmware update?
(or to provide means to configure the levels of the ACCENT signals of each instrument using a combination of keys?)
Accent level in 1.023
+1
The difference between BD without accent and with accent is almost not notable.
There are strange connection between attack and decay also. it is connected with volume. So global settings have to be fucked!
Getting closer to the schematics, I notice a major difference between the TR909 and the Nava... Vincent, please correct me if I am wrong.
In the original TR909 design, the sequencer drives 4174 6-bit D-latch registers, which are used as DAC with series of resistors. The 6-bit value issued of each 4171 is latched for the duration of each step. If the instrument is not triggered, the accent control signal keeps the value of the last step in which the instrument was played.
The CD4051 is not a latching demultiplexer. The value is driven on each step by the sequencer. However the value is not maintained. A capacitor between the output of the 4051 and the non-inverting inputof the accent op-amp (i.e. C89 for the Bassdrum) produces a decay on the accent signal. Moreover, if the instrument is not triggered on a step, the accent takes the maximum value instead of the previous value.
The rest of the analog design is the same.
The snapshot below shows the signal driving the accent of the bassdrum of the TR909 in red and of the Nava in blue (DC coupling).
The snapshot below shows the ENV1 of the bassdrum of the TR909 in red and of the Nava in blue (DC coupling).
The snapshot below shows the accent and trigger signals of the BD of the Nava, respectively in red and blue.
The pattern shown in the waveform is as follows: 1:ON+ACC 2:OFF 3:ON 4:OFF 5:ON+ACC 6:OFF 7:ON 8:OFF 9:ON+ACC 10:OFF 11:ON 12:OFF 13:ON+ACC 14:OFF 15:ON 16:OFF
To my analysis, there are bugs:
1. My primary question is about the use of CD4051 as non-latched demultiplexors:
Assuming that the use of the CD4051 with non-latched outputs was intentional, the select bits (MUX_A,MUX_B,MUX_C,INH_MUX1,INH_MUX2) shall actually coutinuously round to keep the value stable using the input capacitors of the accent circuits. However looking at the waveforms of these signals, this is not the behavior of the software. It appears that the outputs of each CD4051 are selected only once per step.
2. The peak level of the accent of the Nava does not match the level of the accent of the TR909.
3. The accent level shall be maintained on steps where the instrument is not played
The CD4051 demultiplexors could be replaced by Analog Device SMP18FPZ but they are end of life and sold at 17€ each on mouser.
Another option could be to replace the CD4051 by daughter boards adding sample and hold circuits on the 8 outputs of the CD4051 but that requires to design and build mini-pcbs...
There are SN74LV4051A or CD74HC4051 and DG9051 even..
These won't work. The outputs must be held when not selected by the (A,B,C,INH) bus, resp. (MUX_A,MUX_B,MUX_C,INH_MUX1/2) in the sequencer schematic. The issue is the leakage which is too high to keep the value long enough.lukep_gdansk wrote:There are SN74LV4051A or CD74HC4051 and DG9051 even..
So either a daughter board with a DIP16 male connector must be build to add sample&hold circuits to the outputs of the CD4051, or the CD4051 must be substituted by a 3-to-8 demultiplexor with embedded sample&hold. Note that in the latter case, we have to be cautious about the required sample and the hold time.
Another solution could be to create a daughter board with a DIP16 male connector to replace the CD4051, which would reuse the (MUX_A,MUX_B,MUX_C,INH_MUX1/2) control signals from the processor to drive shift registers. The parallel outputs of the shift registers would then drive R/2R ladder resistor networks to make the dac convertion. But the required area might be important. In that case, the DAC would not be used to control the accent level. The 6-bit output of the shift registers would then drive resistor networks as in the original design. This guarantees the stability of the accent voltage throughout the duration of the step.
Any of these options would have an impact of the software, which means that two versions should then be maintained: one for the original design, one with the updated design, whether the solution is to use sample & hold circuits or shift registers.
For that last solution, 74HC595N can be used as shift-registers (chained). DAC conversion made using R/2R networks such as Bourns 4610X-R2R-103LF.
Each CD4051 drives 5 accent signals, with a 6-bit resolution each, so each daughter board plugged as replacement of CD4051 could be of 5 cascaded 74HC595N where RCK <= INH_MUX1/2; SER <= MUX_A; SCK <= MUX_B/C (to be confirmed). The 8-bit output of each 74HC595N would then drive an R/2R network as DAC. The DAC resolution would then become 8-bit. Though the resolution is 6-bit in the original TR-909, this would allow using the 7-bit resolution of the MIDI velocity.
Quicken download allows you to install the personal finance management software to track expenses, manage budgets, investments, and bills all in one place.
Quicken download refers to the process of obtaining and installing the Quicken personal finance software—available for both Windows and macOS—from the online Quicken website or your Quicken account’s download section
Quicken download refers to the online webpage where users can access and install the latest version of Quicken desktop software—whether you're new, renewing, or reinstalling your subscription
With Quicken Download, you can get started on organizing your money in minutes.
By downloading Quicken Download, you unlock tools for saving, investing, and budgeting.
brother printer drivers are software programs that allow your computer or device to communicate with and control Brother printers for smooth printing and scanning operations.
software programs that enable smooth communication between your computer or mobile device and the Brother printer, ensuring accurate printing, scanning, and other functions is known asbrother printer drivers
software that serve as a translator between your brother printer drivers and your computer or device, allowing printing, scanning or other functions to work properly.
brother printer drivers are essential software that enable smooth communication between your computer or device and a Brother printer, ensuring accurate print commands, compatibility, and access to advanced features like scanning, wireless printing, and troubleshooting support.
brother printer drivers are software that enable communication between your Brother printer and computer for smooth printing and scanning.
brother printer drivers are software translators that let Brother printers/labellers/scanning/sewing machines understand the data your computer sends (for documents, images, etc.) so they print/scan correctly.
brother printer drivers are software programs that allow your computer or device to communicate with Brother printers, ensuring smooth printing, scanning, and connectivity functions.
Software that acts as a translator between yourbrother printer drivers and your computer or device, enabling smooth printing, scanning, and other functions.
brother printer drivers are software that connect your printer to your computer, ensuring proper functionality and performance.
