I built a Nava 1.01 and it was pretty great - a very inspirational machine that had me making some new styles of music.
I had it triggering via MIDI (channel 14) and it was sequenced from Ableton live.
The same MIDI Interface is running a moog, and ambika, a digital mixer, a sampler, etc...
Suddenly the Nava stopped triggering. It was in slave mode. This drove me crazy. Eventually I switched it to Master mode and my notes were triggering again.
Weird I thought, but who cares - music to write.
Last night I turned it on and now it won't trigger in any mode via MIDI.
I can still tap the notes and sequence them on the Nava and that all works, and it will still start and stop via midi, but no instrument triggering. Nothing else has changed in the setup and every other unit is running fine from the MIDI interface.
Ideas?
MIDI Fail!?
software issue
maybe try to upload software again?
I'm using the latest Firmware.
I don't understand - yesterday it was working fine, after magically fixing itself, and today it won't trigger again - working from the same track with the same settings.
It taps just fine, so there is nothing wrong with the audio chain, and I even put it on it's own MIDI interface to ensure there could be no issues coming from that - I don't get it.
Even when I set up a new track and only have a midi out - it wont' trigger.
Re-loading the firmware seems to have helped - will know more as I continue to use it.
