I have schematics for 1.0l but it would be great to have the schematic for 1.01, the version of the machine I'm trying to build.  As it stands, I'm having a lot of problems with traces being broken somewhere along the line.  Trying to hunt those down is difficult.  An brd file would be great so I could follow the traces.
Thanks
David
				Schematics for Nava 1.01
As far as i know, the only things that differs in 1.01 vs 1.0l are the trace near IC11 which had to be cut and replaced by a wire, the three transistors footprints in the snare section that were wrong and the diode in the master (it's listed here viewtopic.php?f=24&t=1208&p=7684&hilit= ... stor#p7684), so the schematics for 1.0l and 1.01 are the same I think, only the pcb has been updated between the two versions.
Although the .brd must differ a bit from one version to the other, anyway it's not really helpful cause there's only the silkscreen.
To look at the trace, check the top/bottom layout pdf files in the download section (http://www.e-licktronic.com/en/nava-par ... clone.html), but it's also for version 1.0l so there must be some little differences around the sections i mentioned above, all the other sections remain unchanged.
Hope you'll get this fixed.
Bastien
Bastien
Ok, thanks!
