- Posts 4
- Posts 30
Check IC5 if it is soldered properly and also check diode orientation as well. IC5 is a 7915 negative voltage regulator. Start with that.
- Posts 4
The Diode orientation works alright like you can see on the board. And the Diodes are working like they Seouls. How can i check the ic5 or do I need a new one? Thanks for answering
- Posts 104
Probably using a DC wall wart. You need one with an AC output.
- Posts 30
Good point "ikke"
Sud76137 did you check your power supply is it 15V AC or is it 15v DC it should be AC.
- Posts 30
cso5 wrote:Good point "ikke"
AS "ikke said
- Posts 30
Süd76137 how did you go??
- Posts 4
cso5 wrote:Süd76137 how did you go??
thank you very much for your support.
i love you guys
