A few weeks ago I decided it would be a nice idea to apply the fix for the Bass Drum Buzz (trace was too close to ground plane so, as advised, I replaced the trace with a wire on the component side). After the fix, the BD was not working at all, so I must have broken something in the process (it was a messy desoldering process).
At first I thought I must have damaged the IC11 OPAMP while desoldering it so I replaced it with a new one, but still no luck (in the process I put a socket for IC11). So now I'm left with a broken BD which is horrible. Since I have a USB scope I measured all the labelled points on the silkscreen and here are the results:
[*]TRIG: OK got a correct trig
[*]PULSE: OK got a pulse waveform
[*]ENV3: OK got an envelope
[*]VCO: OK got a saw wave
[*]Noise: OK got noise I think (SD works anyway)
[*]ENV1: 0V I think
[*]ENV2: constant -10.4V
[*]ACC: constant -13.75V
As you can see, there is something wrong with ENV1, ENV2 and ACC I suppose? I have no idea what they should behave like since I'm no electrical or electronics engineer (although I'm a materials engineer).
Would someone be able to narrow down the problematic area knowing this? I can measure more points if you tell me where.
I think I accidentally triggered a bass drum sound while probing with my scope by touching one of the pins (I had the nava hooked up to my speakers) but I was not able to reproduce, but it's encouraging knowing it can produce some kind of sound in the bass drum section.
THANKS!
