Just finished my build and it's pretty close. Working instruments are:
Snare Drum (works)
Low Tom (works)
Rim Shot (works)
Hand Clap (works)
Hi Hat (works)
Crash (works but a bit quiet)
Ride (works)
I have a very quick click for the Kick Drum and the Hi Tom... Absolutely nothing for the Mid Tom. Should I be looking at Op Amps first as the guilty party? Voltage tests good (+14.96 and -15.14) on all points of the op amps.
A few instruments not working
Ok. Swapped all of the op amps, powering up and testing each time. Same exact results every time. So definitely not the op amps. Swapped a few transistors and got the same results too. Hmmm... Any other thoughts here? Still have a "click" for kick and mid tom and no life at all out of the high tom. All the IC's, op amps and transistors are socketed, so they're relatively easy to swap. Thinking it might be deeper than that. I'd really appreciate any insight!
Yeah, as I found out, there's no use swapping op amps if there's nothing being fed into them.
I don't know anything about electronics but I borrowed an oscilloscope and poked around to see how far the signals got before they disappeared. You'll need the schematics.
I managed to find a missing solder joint (d'oh!) but never solved my dead hi-hat issue. I'm told my next step should be to use the silkscreen & trace diagrams to check the continuity of all traces for the affected instruments.
The original 909 service manual may be of help decoding what your kick drum transistors should be doing, but again, you'll need an oscilloscope. Raf's 909 circuit analysis is quite useful too.
First of all D-wreck, thanks so much for actually replying! I busted out the oscilloscope and took a crack at it. I checked out the schematic and tried my best. It seemed like I got good readings for the trigger... But I'm guessing that wasn't a problem anyway since I could hear a click from the outputs the whole time. I think I'm just too much of a noob to really know what I'm looking for to even see the signal of the oscillators for the kick.
This is a meticulous build with very a very clean solder job. Anybody with good (deeper) troubleshooting abilities on here want to make probably the easiest $200 you'll ever make? LOL. I'm sure there's probably just one or two components on each instrument (kick, mid tom and high tom) that aren't working. And everything else is working 100% perfect.
I'd be willing to ship my build to someone to troubleshoot and fix for $200 if anybody would be interested. I'll include a return label, so all you'll have to do is call UPS and schedule a pickup or drop it at a UPS store when it's done. I REALLY wish I was able to figure it out on my own, but I just don't have any more time to spend (it took a pretty long time to build, after all
). I really hope someone can help me out!
Just saw your post about Nava repair, I can take a look if you're interested, but I'm located in France. If you're in the US maybe it's better if you find someone here (less shipping fees and import charges). Anyway, I would be happy to help getting this Nava sound as it should
Have a good day,
Best,
Bastien
Have a good day,
Best,
Bastien
Hey Bastien! Thanks so much for the offer! I'm going to try to find somebody in the U.S. if possible first, but if I can't find anybody, I might take you up on that!
Yt.be/activate provides a simple way to connect YouTube with smart devices.
Activate YouTube on Roku, Firestick, or TV with Yt.be/activate
Yt.be/activate is the one-step solution to sync YouTube with large screens.
Use Yt.be/activate to enjoy seamless YouTube streaming on your TV.
Yt.be/activate lets you link your YouTube account using a quick activation code.
Enjoy YouTube on gaming consoles by activating at Yt.be/activate
Yt.be/activate is designed for quick YouTube setup on smart devices.
Enter the device code at Yt.be/activate to unlock YouTube on your TV.
vizio.com/setup is the quick link to activate and configure your Vizio TV or device.
Set up your Vizio Smart TV or soundbar easily by visiting vizio.com/setup
vizio.com/setup helps you connect and personalize your Vizio device in minutes.
Use vizio.com/setup to link your Vizio TV to Wi-Fi and streaming accounts.
vizio.com/setup is your guide to complete the initial setup of your Vizio products.
Configure apps, internet, and settings for your Vizio TV at vizio.com/setup
vizio.com/setup allows you to register and activate your Vizio SmartCast device.
Get step-by-step instructions for your Vizio device setup at vizio.com/setup
vizio.com/setup is the one-stop page for activating and customizing Vizio TVs.
Easily connect your Vizio device to streaming services via vizio.com/setup
