Since i have chanching the pins of the transistors like it is in the circuit diagram,  my Tone and Snappy doesn't work.
I have rebuilt it to the mixed legs. And it also doesn't work.
				[SOLVED] Snaredrum - Tone and Snappy no function
I had also swiched the legs and I I had a constant feedback from the snare after that. It't didn't go away after I swapped the legs back!
Today I found the fault by pure coincidence.
In my case one of the diodes: D58 / D61 was broken!!
After I changed them the Snare worked again.
Might be a start for you!
Hey thank you.
I will look tomorrow
diods are ok
same here. do you know what's wrong?
				does your noise work?  snappy and tone are tied to the noise.
				bass drum and toms working good so noise should work then. i have a problem with handclap but i think i fried BA6110... i will check noise with oscilloscope.
																																								My noise is verry low.
I have changed the 14006 and see, one of it is defect.
So it couldn't work exactly.
Now i wait for new ic's
Thank you for this hint. noise is fixed and the Snaredrum runs as well.
I´ve changed the 14006BCP and it is runing
Now i make the Bassdrum Buzzz fixing and than the Clap as the last step for today
