Nava v1.0 Firmware
I noticed one bug: when I program sequence and some tools do not use (low, mid or hi tom example) and real-time play (several times switching to mute mode and back), and then try to add to the sequence mode even what some tools which it was not originally written - they simply can not be played, a feeling that they are enabled in mute mode, but it is not so! necessary to maintain the pattern, turn off and turn on the machine again, and only after that comes the sound
very strange and not nice! Try to play this way, can anyone else noticed this? Last version 1.019
Thanks, that was useful information. Had a problem with Nava freezes when played with midi. Works better in slave mode.drifter7508 wrote:Running in master when played with midi= not working so good.
Works better in slave mode. But maybe it's supposed to be in slave mode.
Vincent... any updates on when a new FW will be available?
1. The Nava cant be played properly with midi as we have reported as a bug.
viewtopic.php?f=25&t=1014
2. The Nava cant be used as the real 909 (and 808+yocto) with the seq. (Pattern change!)
These 2 problems are critical! No info, no new firmware for a long time...
I'm sure he is working on it. Guess he has a lot to do preparing the next generation of Nava and Yocto boards at the moment...
Well. The Nava is pretty much unusable in this FW state as both studio and live machine... so I think this should be the priority.
I'd also like to see a firmware update, at least for the critical things.. there are just a few things left to be sorted..
Dear Diyer,
Please be patient a little bit more on the firmware update.
We apologize for the delay.
Many bugs in midi play mode!!!! Not stable!!! sound constantly breaks down and some instruments play by themselves !!! too bad it is not possible to use !!!
When controlled by MIDI, Nava doesn't respond correctly when added swing to MIDI track in DAW.
Seriously? So, all this time there have been no work done for the firmware and no timeplan at all?
(From what I can read out from the new FW developer).
Im still waiting to be able to use my Nava. Right now its not possible with the current fw state.
