comboy wrote:0.0022uF missing.
3 on the bom.
bd needs 1, sd needs 3
I feel like the first person to actually test the BOM :-/
Stumbled upon this as well. :-/
Missing one.
3 on the bom.
Thanks for the tip about the capacitors. Could you indicate which capacitors from the BOM are poly box? It's not readily indicated. Better would be even to have the Nichicon equivalents but I don't want to push itdinsync wrote:there are little to no metal film caps in the bom (instead it uses poly box). You should really use those nice Nichicon metal film if you want it closer to the original machine(i was lucky to have a good stash of these here)
1K and 1K2 resistors quantity updated on Mouser BOMcomboy wrote:I have plenty of 1k resistors left, but am missing nearly all 1k2 resistors from the sequencer.
havn't counted them yet but my guess is there are 1k instead of 1k2 resistors in the BOM.
Mouser BOM have 91pcs of 100k resistors and you need 91pcscomboy wrote:1 x 100k missing
SD parts list updated:comboy wrote:0.0022uF missing.
3 on the bom.
Added to the Mouser BOMcomboy wrote:0.1uF film missing
Parts list updated with right capacitor typecomboy wrote:C84 is listed as film capacitor but I only have ceramic capacitors with 220pf on the mouser BOM
Half of the IC65 is use in HH section as amplifier and the other half use in crash section as amplifier too.comboy wrote:ic65 listed under hihat but located in ride section
Added to the Mouser BOMcomboy wrote:pin header for LCD missing
these are in the Mouser BOMcomboy wrote:4 LED spacers missing
All Mouser BOM changes are describe here viewtopic.php?f=24&t=802#p4439hofmann25 wrote:Thanks Comboy, Vincent, Paul and everyone else who has posted updates for the BOM.![]()
Just thinking for those of us who have already bough our parts (And haven't started) I think it would be helpful to make a document or new topic only Vincent can edit (To keep pure) with a list of all the missing and incorrect parts.
What do you all think?
The new Mouser BOM is good for those who haven't bought yet but not so helpful for those who have.
