*edit
These are confirmed as well. The panasonic parts technically fit but are tall and weird looking (and obsolete)
 27nF: QYX2A273KTP
12nF: QYX2A123KTP
18nF: QYX2A183KTP
 mOBITh wrote:I've upgraded my Mouser BOM to include metal film resistors (1%) ..
The 24-detent Bourns encoder are available and there are 2800 on hand.e-licktronic wrote: EDIT: 06/25/15
-Change 1uF 50V Panasonic electrolytic capacitor referency (out of stock) by Epcos/TDK
-Replace 24 detents Bourns encoder (out of stock) by no detent bourns encoder.
24-detent is better to use in roll mode. It's more accurate to choose roll scale. To adjust tempo, one detent equal one bpm.wavydave wrote:The 24-detent Bourns encoder are available and there are 2800 on hand.
24-detent (2809 available): http://www.mouser.com/Search/ProductDet ... 4220FS0024
No-detent (156 available): http://www.mouser.com/Search/ProductDet ... 4020FS0024
Which one is preferred and why?
Try 810-FK18C0G1H221J instead. It's a 5% tolerance C0G/NP0 so it's very temperature stable, has the same max voltage (that or more will be OK) and the same lead spacing.Don Solaris wrote:Multilayer Ceramic Capacitors MLCC - Leaded 220pF 50volts 10% X7R 2.5mm LS
Mouser Part No: 594-K221K15X7RF5TL2
Availability: 0
Estimated Dispatch Date: 29.10.2015
1: The original used carbon resistors, Metal film won't hurt, but you'll end up with lower, perhaps too low noise. It's tricky, sometimes you don't want to use modern, "too good" components. It can sound too clean or stiff. My 9090 with all metal film resistors sounds *very* clean, but I like that.Neurologik wrote:Hello to everybody I put KIT, Why discourage the use of metal resistances 1% I thought was better in fact more 'I also measured the condensers to have all the most' close as possible to the value marked. For example if you usually do not find the value I aveda even in 0.1% resistors.
Tell me if you think I'm wrong because if the roland 808 did not measure each one played it slightly different is not it?
And to know if you lose time checking values worth it or not what you think?
