Often asked ourselves the question how to order a full kit,
Here is the procedure to be followed:
- 1. Order Yocto v1.0 Kit + 10x whites knobs + 14x orange knobs + 2x Davies 1510 Black Knob on e-licktronic Store. you can choose 21mm knobs for Tempo and Master volume
2. Order this Mouser project http://www.mouser.com/ProjectManager/Pr ... b0800f3b90 Mouser BOM last update: 9/13/2016
3.Go to your Mouser basket and check that you get 111 parts and Check out. You can add to your basket 15VAC 1000mA wall mount AC psu if you need one too.
4.If you need a acrylic case download Yocto EPS file
5.Go to their site (www.ponoko.com or www.formulor.de) with the file of the box (please choose P3 (384 x 790 mm) material sheet size), choose your material and order.
Enjoy!
EDIT: 12/09/16
-Yocto mouser Bom updated
EDIT: 9/13/16
-220uF 35V Panasonic capacitor replace by Lelon
-Harwin Hex 10mm Spacer changed reference
-BOM complete
-BOM Updated and complete
EDIT: 8/15/16
EDIT: 6/8/16
-BOM Updated
EDIT: 5/28/16
-2200UF electrolytic capacitor replace by Kemet
EDIT: 5/23/16
-18nF Nichicon capacitor replace by Kemet
-820K KOA Speer resistors replace by Vishay
-1K TE connectivity resistor replace by Vishay
-0.01uF Nichicon film capacitor replace by Nichicon other referency
Grayhill encoder and Molex jumper cable still Out of stock
EDIT: 4/12/16
BOM complete
-TL1100F160Q e-switch replace by TL1100F260Q
-25LB22-H Grayhill encoder replace by 25LR22-H
-18nF Panasonic capacitor replace by Nichicon
As GrayHill 25LB22-H encoder will be out of Stock by Mouser soon we a have few available in the shop
EDIT: 3/24/16
BOM complete
- 3mm Red Led Lite replace by LTL-1CHE 3mm Red Led
-6N138M replace by 6N139M
EDIT: 3/8/16
BOM complete
-0.0033uF Nichicon capacitor replace by Kemet Film Capacitors 100volts 3300pF 5%
-10uF 25V Nichicon capacitor replace by Lelon Aluminium Electrolytic Capacitors - Leaded 50V 10uF 20% 5x11mm
EDIT: 2/13/16
BOM complete
-0.0033uF Nichicon capacitor replace by QYX2A332KTP
-0.0022uF Nichicon capacitor replace by QYX1H222KTP
EDIT: 2/1/16
BOM complete
-0.056uF panasonic capacitor replace by ECQ-E2563KB
-16Mhz crystal replace by FOXSLF/160-20
EDIT: 12/22/15
BOM complete
EDIT: 12/02/15
-0.027uF 50v panasonic capacitor obsolete replaced by 250v
EDIT: 11/21/15
-Mouser BOM Updated
Molex 4Pin 2inch cable out of stock (available in 8 weeks) do not order this cables if you don't need it
You can use single wire instead.
EDIT: 09/28/15
-1uF 50v LELON capacitor replaced by Nichicon
-39nF Nichicon capacitor replaced by Panasonic
-0.47uF 50v Panasonic capacitor replaced by Nichicon
-150k Xicon resistor replaced by Yageo
-250k 3362P-1-254LF Bourns trimmer replaced by Bourns 3386P-1-254LF
-33nF QYX1H333KTP Nichicon capacitor replaced by Nichicon QYX1H333JTP3TA
-3n3 Nichicon QYX2A332KTP capacitor replaced by Nichicon QYX1H332KTP
EDIT: 08/20/15
-10k resistors changed by Xicon
-120k resistors changed by Yageo
-68K resistors changed by Yageo
-56K resistor udapted by Koa Speer
-0.022uF capacitor changed by Kermet
EDIT: 07/25/15
-Nichicon 0.1uF capacitor referency updated
-18Kohm resistor out of stock updated by KOA speer
-33uF 25V Lelon capacitor (out of stock) changed by Nichicon
EDIT: 07/9/15
-0.012uF Panasonic film capacitor out of stock updated by Nichicon
-39Kohm resistor out of stock updated by KOA speer one.
EDIT: 06/29/15
Thank you for having accused us of this change.220p: The parts in the mouser are 1000V, WAY too big, and the lead spacing is wrong. Recommend K221K15X7RF5TL2
2.7n: The box 5mm spaced parts that are in there now are a nightmare to mount into 2.5mm spaced footprints, maybe QYX1H272KTP?
1.8n: same (even worse considering their position) as the 2.7n. QYX1H182KTP?
Capacitor lead spacing updated.
EDIT: 06/25/15
-Change 1uF 50V Panasonic electrolytic capacitor referency (out of stock) by Epcos/TDK
-Replace 24 detents Bourns encoder (out of stock) by no detent bourns encoder.
EDIT: 05/30/15
-Change 1N4004 referency (out of stock) from Rectron to Diode Inc.
EDIT: 05/26/15
-Change 0.039uF polyester film capacitor referency from Panasonic to Nichicon
-Change NJM4558D (out of stock) by NJM4558DD
-Change 6N138 (out of stock by 6N138M
-Change 1N4148-T (out of stock) by 1N4148 fairchild
-Change 820Kohm resistor referency (out of stock) KOA speer
-Change Heathsink referency
Now everything are in stock and available
EDIT: 05/07/15
-Delete Atmega1284P in the Mouser BOM (now include with the Yocto half Kit)
EDIT: 04/22/15
-Replace Atmega1284-PU by Atmega1284P-PU
EDIT: 04/13/15
-PEC16-4220F-S0024 Encoder on Backorder by Mouser (Factorylead time 16 weeks). Alternative order by Digikey http://www.digikey.com/product-detail/e ... ND/3534239
- 6mm M3 black screw on Backorder by Mouser (Factorylead time 3weeks) . Alternative order by Barenco http://www.barenco.co.uk/fasteners/mach ... 00000-prod
-Updated 4K7 resistor quantity to 29pcs
-Replace Backorder parts with equivalent by Mouser
EDIT: 03/23/15
33uF/6.3v capacitor replace by 33uF/25v
EDIT: 03/22/15
I just recieved my BOM from mouser in the mail and unfortunately I just trusted your list without going over it. All the film capacitors are listed as cermamic in your new BOM.
Changed by Film capacitor
Update with right 220uF valuePlease revise your whole BOM. I just started my build and 5 minutes in aside from the last issue C11 calls for a 220/35 capacitor and the BOM has a 22/35v listed
It is a little hard to clip it on the board but this are the right one.Output jack lead is too wide for the pcb hole.
