S-TRIG
Any hope of getting this fixed soon?
Ditto, really looking forward to getting this fixed.rashed wrote:Any hope of getting this fixed soon?
bump, any updates on this?
bump
E-licktronic, can you please provide us with an updated ETA on this?e-licktronic wrote:This problem will be fixed in the updated firmware.pulse_divider wrote:Gonna keep bumping until I get an answer... has or will this be fixed with a software revision?
Will be ready with the new batch (December the 1th)
Hello
You can change the Q1 and Q2 from 2SA733 to 2SC945 on the IO_board and you get V-Trig
Dan
Dan
Cool, would that be for Trig 1 and Trig 2?danne71 wrote:Hello
You can change the Q1 and Q2 from 2SA733 to 2SC945 on the IO_board and you get V-Trig![]()
Dan
ah, finally a solution! updated my trig1 to v-trig and keeping trig2 as s-trig. many thanks!
seems though the subtle grounding noise problem still exists. any ideas on that one?
it comes around when i have both audio out from the yocto and a trig cable plugged into another synth. if i pull out either one, the grounding disappears. but both plugged at the same time it's always present.
Hello
Simply bend up the contact plate for the ground on the trig-jack to prevent it to connect the ground to the plug.
Ok its not the most proffesional way to solve this but it works....
Or you take a cable Tele/Tele and cut the ground in one end and use only for the trig-output.
sorry for bad english
/Dan
/Dan
Its one transistor for each trig...lfo2vco wrote:Cool, would that be for Trig 1 and Trig 2?danne71 wrote:Hello
Dan
/Dan
