				- Posts 21
I've noticed I got S-TRIG on the two trigs outputs and I'm looking for clues to solve this anomaly... Another question about the third trig output : how do you connect the jack to the I/O board ? Thanks !
				- Posts 21
						Does anybody have an idea about this "s-trig" issue ? I suspect a transistor but I don't know which one I have to check...
 Thank you !
				- Posts 519
						Dear Sal Mocco,
How did you find that you 've got S-trig instead of v-trig.
Do you have a scope ?
Because i don't think both trig out will be faulty at the same time, but it's possible too.
				- Posts 21
						Hi !
Thank you for your answer. I noticed this malfunction because of the answer of my SH-2 to those triggers (continous gate and retrig when the trig step sequenced was lighting), so I tested with my voltmeter and there was 5V at both triggers outputs even without trigs sequenced. I've just tested five minutes ago with my old scope (not a very accurate one) and I have an impulsion of 0V (5-10ms) on a 5V signal on both trig outputs. I don't know if it is relevant but I can't either do rolls with triggers (maybe it's not possible even with a normal gear).
And if someone can explain me how to link a jack to the third trig output, it would be just great !
Thank you again !
				- Posts 519
Check that you get 0V at Q1 and Q2 base on the IO board.
Check that this transistor are 2SA733.
Tu use trig 3 out simply connect the tip of jack connector (or other) to the trigout3 pad or you can add the same circuit as the other trig out to prevent damage.
				- Posts 21
						Again, thank you !
I got 5V on both 2SA733 transistors (Q1&Q2) bases. I guess my mistake is upstream in the circuit...
				- Posts 85
				- Posts 21
						Clever ! Thank you
				- Posts 21
						If someone has more trails about this s-trig issue... I'm here !
				- Posts 21
						Sorry to insist but it's very sad to see my yocto opened without being able to repair it, nobody has an idea about that issue ? Thank you very much !
