Nava
  • hofmann25 wrote:
    pistrix wrote:
    southpole wrote:small note on the BOM: it's worth going through, some parts are just below the threshold to 100 piece discount and for some components there is a price drop to 1/3 the individual component price which can make the BOM cheaper by ordering a bit more... (probably not news for veterans here)
    Good tip! There aren't many components worth over-ordering, but I spent 30 minutes going through the BOM and shaved about $5.50 off the price. Thought I might save others the trouble..
    1n4148 Diodes (BOM = 95 x $0.053 each ($5.04); but 100 are x $0.019 ($1.90))
    1Kohm 1/4W 1% Resistors (BOM = 58 x $0.08 ($4.64); but 100 are x $0.032 ($3.20))
    22Kohm 1/4W 1% Resistors (BOM = 45 x $0.092 ($4.14); but 100 are x $0.037 ($3.70))
    100Kohm 1/4W 5% Resistors (BOM = 91 x $0.021 ($1.91); but 100 are x $0.013 ($1.30))
    Also, though it appears to be only 2 days old, there are already 3 items backordered on the BOM:
    138x 10K ohm 1/4W 1% Resistors (currently stocked replacement: https://www.mouser.com/Search/ProductDe ... 5FBF52-10K) [note that 200 units cost less than 138)
    8x Film Capacitors 100volts 1000pF 5% (currently stocked, cheaper replacement: http://www.mouser.com/ProductDetail/Kem ... vLAx2PU%3d) [note that 10 units cost the same as 8)
    4x LED Mounting Hardware (currently stocked, cheaper replacement: http://www.mouser.com/ProductDetail/Biv ... c15%2fg%3d) [same as in BOM, but white instead of black at 1/2 the price)
    New BOM total: $174.49
    Old/Current BOM total: $182.26
    Would you consider sharing this project on Mouser? :D
    Many thanks for this, saved me the trouble myself! :)
  • yeah thanks. i didn't post a list because it depends a bit what people have in stock at home already.
    personally, i have very similar rubber feet already, and i recently got a boxed set of Dupont headers which i plan to use instead of the Molex headers... should shave off a couple of euros more
  • I'll see what I can do about the groove. If they are going to run 2000 of them, they might be able to do whatever I ask. I requested samples so once I have those I'll put up an order form
  • pistrix wrote:New BOM total: $174.49
    If you really want to save money you can buy commun component by Tayda then complete your part list by Mouser.
    Here is a Tayda BOM:
    Nava v1.0 Tayda BOM
    Downloaded 1857 times
    price is $30.04
    And Mouser BOM to complete your kit:
    -http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=2beb762c47 price is $61.41
    This Mouser Bom will NOT be updated
    Total = 91.45$ ex shipping
    Good deal ;)
  • e-licktronic wrote: If you really want to save money you can buy commun component by Tayda then complete your part list by Mouser.
    Tayda_Nava_v1.0l_Bom.zip
    price is $30.04
    Good deal ;)
    TOP! 8-) thanks alot!
    best,
    Sub
  • Just out of curiosity - how many kits will be available on monday?
    I also just ordered the parts, so I really dont want to miss the kit :)
  • AonFluX wrote:Just out of curiosity - how many kits will be available on monday?
    +1
    price is $30.04
    Good deal ;)
    Hi Vincent, thanks for all your hard work! These projects are beautiful! :)
    What time will the e-licktronic website be updated on Monday? St LEU REUNION time?
    Thanks! :) :) :)
  • Have a look here, under the TR section
    https://syntaur.com/roland_drum.html
