Internal power supply and PSU mod
		Nice, did you attach the Ground Loop Breaker?
Thanks for posting
				Hi...i am a new user here. As per my knowledge you should put Cathode to diode 109 and the Anode to diode 110 from the twisted pair of diodes then the 15v from the transformer to the twisted end, your other wire connections are also correct.
				So this one is ok for me? It has 230V to 2x 15V 15VA 0.5A
Living in germany.
https://www.conrad.de/de/ringkerntransf ... 09884.html
				Living in germany.
I read the full article now.. sorry for the question.. solved it by myselfflinte413 wrote:So this one is ok for me? It has 230V to 2x 15V 15VA 0.5A
Living in germany.
Hi...i am a new user here. As per my knowledge the y scale is negative dB. For instance you can see a noise peak at 50Hz in both cases.
The external power supply produces a peak of about -86dB at 50Hz.The internal power supply produces a peak of about -75dB at 50Hz, which is about 10dB higher than the external power supply.Similarly, there is a second noise peak at 150Hz that is quite higher (about 8dB) with the internal toroidal transformer than with a basic external ac supply.
printed circuit assembly
																																								That was my experience as well, internal was noisier. It's a big magnet after all..LulaNord wrote:Hi...i am a new user here. As per my knowledge the y scale is negative dB. For instance you can see a noise peak at 50Hz in both cases.
You must not have done it correctly.Altitude wrote:That was my experience as well, internal was noisier. It's a big magnet after all..LulaNord wrote:Hi...i am a new user here. As per my knowledge the y scale is negative dB. For instance you can see a noise peak at 50Hz in both cases.
Works fine. Especially with the loop breaker
Have you actually measured the noise on a scope?  I have and it was nosier.  Same results as LulaNord
				Why would any of us actually want to? Are we making music here are just making stuff for the shelves?Altitude wrote:Have you actually measured the noise on a scope? I have and it was nosier. Same results as LulaNord
