Some shipping information :
-sending through the Belgian post it would cost 32,80€ to send the enclosure to the EU, the Mediterranean and the US - unless you live in the Netherlands, Germany or France, then it's only 16,40€
-the Belgian post sells boxes at 3€ a piece, that are large enough to fit the enclosure
-I'll probably pack them with styrofoam, so count 1 or 2€ for packing
My friend who was going to help me finish the design for the front plate fell ill this weekend, so I'll only have something to show you guys later this week. Once I have that, and I met with the company, I will start to ask for addresses of the people interested, so I'll know if I should order ten or twenty.
Exploring other enclosure options.
Here's the design I would use to print on the enclosure.
Could somebody please confirm that the sound names above the step buttons are correct? I don't have my yocto working yet, I just copied them from the sound selector dial to the corresponding numbers.
Dear Elshctroumpf,
Nice design you made
Yes it's correct.Could somebody please confirm that the sound names above the step buttons are correct? I don't have my yocto working yet, I just copied them from the sound selector dial to the corresponding numbers.
@ElSchtroumpf
Please let me into enclosure group buy!
I want to purchase 2 pcs.
many thanks for helpful effort for us.
Wonderful!!
Count me in!
EDIT: I may need 2..
Also, the labels for the outputs need to be centered (not all of them are perfectly centered)
Count me in!
it looks great!
But shouldn't there be holes for the four scale LEDs too?
Also interested!
@ rv0 : good catch, I didn't even notice it. It was almost midnight when we finished working on it, so we missed a few things. We'll be doing the final adjustments this weekend, so I'll be sure to allign them.
@ misa : this is the design for the printing, for the cutting they will use the .eps file provided for the acryl case. The purple hole cutouts are merely for placement reference.
Other planned changes : I will change the '15VAC' label to 'Power', since there will be cutouts for the 15V socket, as well as a C14+switch in the enclosure. I will also add the separation in the bottom bar that has the 16 numbers in it, the same way as it is on the 808. This is just for clarity and easier reference, since there are only 12 sounds.
understandable, reason I noticed it right away is because we also made the same error with the n0nx0x panel I posted here earlier, there the label for CV is not well alignedElSchtroumpf wrote:@ rv0 : good catch, I didn't even notice it. It was almost midnight when we finished working on it, so we missed a few things. We'll be doing the final adjustments this weekend, so I'll be sure to allign them.
Good call on changing 15VAC to "Power"
Just looking at the font, it seems kinda thin, you may have to increase the font weight a little bit
I'm definitely interested also! I'm on the waiting list for 4th batch - planning ahead though!
looks great!
looks great!
