Ok I have to check the TOMs Volume again. I had all of them on the same Level (half way) and the High Tom was clearly louder than the others.
Anyway, the Feedback loop in the snare on Stopping the Sequencer is the bigger issue for me right now.
Did anybody also swap the transistor legs already?
i have also the problem like all other here with mid tom. but i have a second problem with to short decay on it.
Decay on my mid tom is short as well.
I will check my env 3 tomorrowzephyrin wrote:Here
peskado could you tell us if you have the good waveform for the 3 env of SD ?
Pin out is indeed ECB
+1 for PDF with tracesAonFluX wrote:+1 for getting pdf with traces - then at least the forum could help each other much better.beeb wrote:You're definitely better off now than we were a couple of months ago! But I would advise reading all big threads in the Nava Hardware section on this forum before you start, and making notes of remarks people have made for what's wrong in the build guide, etc.xone wrote:seeing this is not exciting considering I just ordered a kit, wondering if I should cancel my order...
I guess the fact that Vincent was on vacation the past month doesn't help with this feeling, but still, we've been asking for a pdf of the traces for ages and still nothing without a reason for this refusal.
And yes - this kit ran way more expensive than first figured, think I have put down 3 extra orders.
Can someone please post a picture/example of the resistors how you solved it on the pcb.
So we don't mix the legs up (again).
Guess the legs are to short to twist now.
This is how I did it:
The rightmost pin is the Base (according to my transistor tester and the data sheet). I switched Collector and Emitter as in the original 909 schematics but now I got this "feedback loop". I don't know if it is related to twisting the legs...it was all good before!
Did anybody else test this??
@Vincent
Did you test how the twisting of the legs affects the build or do you have a feedback loop as well?
Did you build a NAVA with a PCB you sell in the kits?
@Vincent
thanks for the pic, i'm going to try this as soon i'm not to lazy... going to use sockets to be able to easy swap back if it causes problems...
I'm eagerly awaiting your results...I should also have put sockets in. Depending on your results I'll consider fixing that.
