Mid Tom: low volume. Hi Tom: Overdriven/ distorted...
welcome back
Perfect, thx for letting us knowe-licktronic wrote:Dear,
We are working on the firmware to solve the Mid tom low level.
Be patient, a firmware update will be available soon.
Dear,
Update v1.019 available here
It should solve Middle tom low volume issue.
Could someone please post an installation guide? Is MidiOX used for this and what would the settings be? Thanks!
All you need to know is in the manual.
Use MidiOX
Options/MIDI Devices and select Midi output to use
Options/Config Buffer and set as the Nava manual states
Prepare the Nava for recieving Sysex as manual states
Then Actions/Send - Sysex file
Wait for the transfer and Nava to update, which will start as soon as its done.
Ok, so again RTFM! I could have got it by myyelf...
Thanks anyway for the detailed description AonFluX!
Mid tom now at correct volume, but has anyone got a shorter decay on the mid tom than the two others?
yes, decay is still a bit shorter compared to the other 2 toms
