effegee wrote:
- Accent Per Instrument
A different accent pattern for BD, SN, LT, etc.
I've noticed that accented rolls (holding down the accent button when rolling a snare, etc.) are independent of Pattern accent, so it seems like this could be done. The Quicksilver 606 CPU has individual instrument accent and global accent (in a retrofit to the TR-606).
+1 - I own a Quicksilver 606 and it's really a joy to have individual accent!
- Rotate Pattern
Rotate left and right per step, per four steps, per 8 steps, both per pattern and per instrument.
+1 as well!
Yes to both of these! The Quicksilver 606 is amazing in this regard. Hitting a step button once for half level and twice for full level is an easy way to get much more subtle variation in patterns.
Also, enabling the roll function when clocked via external midi is huge for me...
				[Wish List] Yocto OS Update Thread
If connected via midi, is there a way to stop Yocto from playing without stopping the midi? wish there is a way.
Shuffle is also a good to have function
+1truman_k@yahoo.com wrote:If connected via midi, is there a way to stop Yocto from playing without stopping the midi? wish there is a way.
fix viewtopic.php?f=16&t=1081 this
				I really miss tap entry..
Ideally in EDIT mode, pressing the "shift key" would enter a note at the current step for the current selected sound (similar to 606, 808,..).
In fact, my yocto already has a note with "TAP" inserted behind the switch
Yeah, 'tis a good feature! Hope to have it soonrv0 wrote:I really miss tap entry..
+1 here!rv0 wrote:I really miss tap entry..
not critical but useful feature request:
When in EDIT mode, rotating the Instrument select switch could (briefly) give visual feedback using the leds of the corresponding step switches
as i can tell from experience: its hard to see which instrument you are selecting when in a dark environment
Neat idea, I'll keep it in mind!rv0 wrote:not critical but useful feature request:
effegee wrote:- Sysex dump/load of patterns & banks
- 1/8 note roll
+1 to both of those
spend quite a while programming a liveset into the yocto, would love to save it somewhere.
