Dai che è facile!Masuto wrote:Amazing! Will try tonight!!! HUGE THANK YOU!!!
F.
 But the result will should be way tighter, simpler and easier to maintain.
  But the result will should be way tighter, simpler and easier to maintain. ). Edit: with this rework the tap mode will work a lot better, no more missing/double triggers!
I'm already using that one.. Also think Cocteau mods are using it. Can't expect people to drill holes in the case for a feature like thathelectromagneticus wrote: It's worth noting that the unused third trigger pin on the ATMEGA could be repurposed as an input...
AAAAND... no it's not working LOL i told you guys i am very unlucky with these things.rv0 wrote:If you get stuck people will help you, don't worry!
Haha don't worry, some tips to help you:Masuto wrote:AAAAND... no it's not working LOL i told you guys i am very unlucky with these things.rv0 wrote:If you get stuck people will help you, don't worry!
I followed your instructions to a tee. downloaded E6, set config and all. I tried a delay of 200, 300 and turbo set to none or 1x
-i put YOCTO in PATTERN PLAY MODE,
-i press on and 1-2-5. All leds blink twice.
-i am quickly sending the .syx out of my MIDIMAN (cant get more basic than that).
NO LED play. All leds are off.
When the send bar is through, after half a minute YOCTO shows the blinking first pattern light. THATS IT.
To check features, i tried to edit a pattern using tap (shift) and it's not working
i tried also using midiox, 300 delay.. no avail.
Sorry to sound retarded but:rv0 wrote: - does not matter which mode yocto is in, as long as it's off when you start
- set delay to 16.. 200 is probably a verrrrry long delay
- Not 1-2-5 but 1-3-5
