it should be closer to 5V according to the spec of the newhaven display it should be between 4,7V and 5,5V.4teenth wrote:Just tested for continuity at all the pins (Well, the ones that are connected, as far as I can see on the board layout), and all good apart from I'm not getting continuity from pin 2 to TM3. I am however getting 4.1V there - is that enough out should it be 5v? If I use a wire to connect pin 2 to TM3 I just get a brighter display of what I currently have now...
on my nava i measure 4,81V
