Hello, i just finished my build, and i have some issues;..First i have no sound for the eeprom's instruments...
All other works well (just have a strange sound for the hi tom...but will check later).
I m unable to check / swap eeprom, because none of the eeprom's instruments works...voltage is ok on all eeprom slot...
Is it a way (without oscilloscope) to check if the eprom's are ok?
i made the mistake to power the nava with the MUX_SH boards plugged and also the eproms plugged, seems to have some issues on my mux-sh build (some warm/little hot smell) , could be a reason to burn the eeproms? Or no interacts between them?
Thanks and sorry about silly questions...
I don t know where to search first ...
Many thanks!
				No HH RIDE CRASH, Help Needed
I am pretty sure that roms are fine. Smth else is broken. Check 5V on TP1 wit and without mux brds.
				Almost certain it’s the left side MUX pcb. Try pop it and test again..
