Then just buy equivalent.BedroomMusic wrote:BOM out of stock parts :
Metal Film Resistors - Through Hole 1M OHM 1/4W 1% - MFR-25FBF52-1M
Metal Film Resistors - Through Hole 100 OHM 1/4W 1% - MFR-25FBF52-100R
Film Capacitors 0.01uF 50 Volts 5% - QYX1H103JTP
Yocto v2.0
R82EC1270AA50K - Film Capacitors 100volts 2700pF 10% just went back order. Can I use a 100volt 2700pF with a 5% tolerance as an equivalent?
It seems like someone went on a buying spree with the 10% units. I can't find them anywhere.
Go figure, I ordered the BOM on Saturday and it said all was in stock.
Yes you can use these. 5% is higher quality than 10% so there's no reason why not.KruseyJohn wrote:R82EC1270AA50K - Film Capacitors 100volts 2700pF 10% just went back order. Can I use a 100volt 2700pF with a 5% tolerance as an equivalent?
Awesome - That was my thought. Being extremely new to this, I wasn't sure there was reasoning behind it -- Perhaps the variance gave a unique sound.
Apprecaite the help!
I've just ordered a Yocto 2 and bought the kit plus the mouser parts and a case, I now need to figure out what I am missing. On the product page, it says the kit does not include "Knobs potentiometers" - I read that to mean that none of the knobs for the pots are included, can anyone suggest where I can find a list of what I need and better still where I can source these ?
thanks
Daragh
thanks
Daragh
check e-licktronic store. there are really nice knobs for Yocto2.
Hi there,
I ordered the kit and the BOM last week, only to realize that both the R82EC1270AA50K - Film Capacitors 100volts 2700pF 10% and the 5% version went back order. Between 6 to 24 weeks. Any idea for a remplacement? Or should I just learn how to be patient...
Thanks for your help and all the infos I've already found through you and this forum
I suggest purchasing them from aliexpress.
https://goo.gl/pwJnvs
I've used it many times without any problems.
Thanks ! I'll try that.
This one is okHiHamGautier wrote: to realize that both the R82EC1270AA50K - Film Capacitors 100volts 2700pF 10% and the 5% version went back order. Any idea for a remplacement?
http://pl.mouser.com/ProductDetail/KEME ... 2boOHjo%3d
5mm raster, but is enough for correct placement
