Now the problem is solved but I had big headaches finding it.
The hi hats were at very low volume, barely audible, but both decays and the volume were working fine. This is the 2nd Nava I built so I could compare the hihats circuit to find the culprit.
I naturally started by checking around IC111 (accent) and IC112(trig) with a scope, same results on both Navas, so I thought that they were working fine.
I jump to the analog part, everything look identical until the 2SA798, so I swapped it with the one from the Ride circuit, same result as before, Hihat still low.
So I checked Q52, swapped it, same. I checked for the 10th time if every value/orientation is good (which is).
I had a give up for a few days, and today I tried to swap IC111 with the one from my working Nava and now it works!
It's really weird cause both the faulty one and the good one were displaying the same voltage variation on the oscilloscope at pin 15, and all other accent provided by IC111 were working fine, could it be current related?
IC111 has probably been damaged because I couldn't trim TM2 to get 5V, IC118 had a cold solder joint, resulting in IC110 outputing 10V and the trimmer wasn't doing anything, and since IC111 is powered by +5V, the 10V at the input must have been lethal. Still weird that it was half working though.
TLDR: hi hats low volume = dead IC111 (CD4051)
				Hi Hats very low volume [SOLVED]
Hi Bastien,
The very same problem happened to me today as I was trying to debug my crash and ride. Now I can hear the hats and the decay works for both closed and open but the volume is way too low
Thanks for sharing your experience
Quicken download allows you to install the personal finance management software to track expenses, manage budgets, investments, and bills all in one place.
Quicken download refers to the process of obtaining and installing the Quicken personal finance software—available for both Windows and macOS—from the online Quicken website or your Quicken account’s download section
Quicken download refers to the online webpage where users can access and install the latest version of Quicken desktop software—whether you're new, renewing, or reinstalling your subscription
brother printer drivers  are software programs that allow your computer or device to communicate with and control Brother printers for smooth printing and scanning operations.
software programs that enable smooth communication between your computer or mobile device and the Brother printer, ensuring accurate printing, scanning, and other functions is known asbrother printer drivers
software that serve as a translator between your brother printer drivers and your computer or device, allowing printing, scanning or other functions to work properly.
brother printer drivers are essential software that enable smooth communication between your computer or device and a Brother printer, ensuring accurate print commands, compatibility, and access to advanced features like scanning, wireless printing, and troubleshooting support.
brother printer drivers are software that enable communication between your Brother printer and computer for smooth printing and scanning.
brother printer drivers  are software translators that let Brother printers/labellers/scanning/sewing machines understand the data your computer sends (for documents, images, etc.) so they print/scan correctly.
brother printer drivers are software programs that allow your computer or device to communicate with Brother printers, ensuring smooth printing, scanning, and connectivity functions.
Software that acts as a translator between yourbrother printer drivers and your computer or device, enabling smooth printing, scanning, and other functions.
brother printer drivers are software that connect your printer to your computer, ensuring proper functionality and performance.
Review past payments and upcoming dues at homedepot.com/mycard
homedepot.com/mycard is designed for easy card access and control.
Monitor all Home Depot credit card activity at homedepot.com/mycard .
homedepot.com/mycard lets you securely manage your credit profile online.
Get complete credit card services from Home Depot through homedepot.com/mycard
homedepot.com/mycard  ensures you stay updated on your card usage.
Manage your credit card anywhere with homedepot.com/mycard
homedepot.com/mycard is the fastest way to pay your Home Depot credit card.
Stay on top of your card dues at homedepot.com/mycard
homedepot.com/mycard makes credit card management simple and quick.
Use homedepot.com/mycard  to set up paperless statements.
homedepot.com/mycard offers a secure platform for online payments.
Manage multiple Home Depot cards easily at homedepot.com/mycard
homedepot.com/mycard gives you 24/7 access to your credit account.
Track your spending habits through homedepot.com/mycard
homedepot.com/mycard  is where convenience meets card management.
Access monthly card statements instantly at homedepot.com/mycard
homedepot.com/mycard helps you avoid missing payment deadlines.
Securely log in and manage your account at homedepot.com/mycard
homedepot.com/mycard keeps your Home Depot credit info organized.
Gain full control of your card services via homedepot.com/mycard
homedepot.com/mycard provides real-time account updates.
Make hassle-free payments anytime at homedepot.com/mycard
homedepot.com/mycard is your digital key to card services.
Stay financially organized with homedepot.com/mycard
