Hi there,
I'm in love with the idea having a yocto.
20 years ago I was quite into electronics and able to solder (tht mostly).
Would you recommend starting now with a project like yocto?
Thanks in advance for your recommendations & ideas.
Clic
				Yocto soldering project recommended for beginner?
Hi
I managed to solder this as a beginner, it took me a long time but it wasn't too hard, although some solder bridges and dry joints needed sorting later on... those problems are relatively easy to find though, the hard part is all the other troubleshooting that comes when you start turning the machine on. Also things like power supplies can be dangerous if you're a beginner of course. I was (and still am really) a real beginner when I started this, and there's no way I could have got the thing working at all if I hadn't had expert help from my Dad... plus this forum is full of advice and helpful people who have already made the Yocto. You sound like less of a beginner than me so perhaps you'll be fine, but I'd recommend befriending an affable electronics engineer to help if you can find one. They tend to gather in real ale pubs on evenings and weekends, at least where I come from.
If you are a beginner, the most relevant tips as found scattered here in the forum, are concisely regrouped in the yocto building post in my blog..
https://masutopedals.wordpress.com/category/yocto-808/
Hi there, thanks very much fo your advice, I think I'll give it a try when I'm feeling lucky.
@Oslek: It's the same here ;.)
@Matsuo: Yeh, I already studied your marvellous collection of tips, they are very worth-while!
Thanks again,
Clic
Thanks again,
Clic
