I have wired a jack to the Trig 3 point on the board, but I don't seem to be getting any signal from it when I set up some triggers in the sequencer. Is anyone using trig 3 successfully? Is it actually implemented in the firmware?
Thanks,
Conor
Trigger 3
hi,
i don't know, but in a related question i would like to ask if it is know
why the accent out was not implemented in the yocto?
(or is it perhaps "trigger 3"?)
Bump!
Anyone have any ideas on this? Does your Trig 3 do anything?
maybe this thread is too old, but does trigger 3 function as it should on the NC sequencer channel? And what is the correct way to wire it?
Trig 3 is straight off of the microcontroller, so I believe it is S-Trig (at least starting with v1.0a), just like Trig 1 and Trig 2. BUT trig 1 & 2 both run through a transistor circuit that filps them to V-Trig. To do the same to Trig 3, you have to add the following circuit (see photo).
Thanks for the image here..
Successfully built a TRIG3 out yesterday.
The image is quite confusing though, it talks about T2/TRIG2 not TRIG3
Also the Yocto_IO_board_v1.0.pdf is more confusing, pin 2 of JP4, which appears to be labeled TRIG_OUT1, but has TRIG3 under it. And there's TRIG_OUT3 on pin 10 there.. I don't get it, very confusing.
For anyone wondering:
TRIG2 OUT on the image is the part that goes to the jack
T2 is the part that goes to pin 2 of JP4
Quicken Download helps track your income and expenses.
Quicken Download for better household financial planning.
Simplify your investments by Quicken Download
Quicken Download to track savings and loans in one place.
Quicken Download helps keep your financial records updated.
Access all money matters by Quicken Download today.
Quicken Download to plan your future finances effectively.
Manage bills and accounts with the Quicken Download tool.
Stay in control of your budget through Quicken Download
Quicken Download for a clearer view of your money.
Financial tracking is easy once you Quicken Download
Keep spending in check with a Quicken Download
Quicken Download lets you plan and save better.
Organize accounts and spending by Quicken Download
Quicken Download makes personal finance more manageable.
Quicken Download to handle all your money needs.
Simplify daily finances with a Quicken Download
Quicken Download helps you reach financial goals faster.
Quicken Download for smooth and accurate money management.
Get a better grip on money with Quicken Download
