1. When I program instruments in tap mode, they usually flam as I'm programming them in. They play back normally once recorded into the pattern. My first thought was that this would be from something I did wrong on my build, causing instruments to double trigger when I press the keys, but the step keys function completely normally otherwise, and most importantly this issue only happens when the machine is playing. When I press the keys in tap mode with the transport stopped, everything triggers normally. This happens on every instrument. Has anyone else experienced this? If there's anything else in the machine related to this behavior I'd happily check it and see if it's just me.
2. When clearing instruments in tap mode, if you release the clear button before the instrument key, the instrument plays when releasing the instrument key and gets recorded into the pattern. If there's a way to prevent that from happening it would help a lot with speed of using the machine.
3. It would be great if it was possible to clear multiple instruments at once in tap write mode. Currently holding clear and multiple instrument keys will only clear the first instrument that was held down. Again this is something that would help so much with playing the machine live.
I'm happy to do anything I can to help get this stuff implemented and to help with testing in general. I have some programming experience but not a ton, I'm checking things out at GitHub now to see if this is over my head or not
