Hey everyone hows it going? I have completed my Yocto and for the most part its making sound but here is the list of problems I'm having.
I went and checked the settings again for the white noise and cymbals and they are both right on the mark.
I also went and checked my soldiers to make sure there wasn't and stupid mistakes.
If anyone can help me pin point and solve these problems that would be awesome.
Master Volume
The Volume is very very quiet but the individual outs are at full
volume.
Sequencer
It just plays every not on (16th) on the sequencer.
Bass Drum
kick has no decay, the low tom has more decay than the kick.
I know it's not going to be like a modified 808 but it sounds thinner and smaller than I think it should.
edit - i just listened to the samples provided by e-licktronics and yes my kick is not even close.
Mid Tom -
self oscillates when above anything other than the lowest tuning. mid conga is fine
Maracas/Handclap
all i get is a constant white noise, no gating at all.
Cowbell
sounds like the tuning is low
Cymbal
all i get is a constant 5k and 15k tones
Open Hat / Closed Hat
no sound at all. both tested fine on the oscilloscope
I need some help fault finding my Yocto.
Dear Craigwiliamsmusic,
It's a lots of problem...
First i think you need to check PSU on all section and GND on all sections it seems to be a ground problem.
I really think it's a faulty ground connection because it's not possible that you burn components on each section.
Could you post HD picture of PCB solder face ?
1.Test with an headphone or a amplifier computer speaker(better with a scope) the signal present on pin 1of MST connectorcraigwilliamsmusic wrote:Master Volume
volume.
2.It's a problem with the common trig. Which instruments are 16th played? all instruments ?craigwilliamsmusic wrote:Sequencer
3. Check R164, R168, R169, C43, VR6 value. Is U12 right powered ?craigwilliamsmusic wrote:Bass Drum
No idea, need a sample to check what 's happen.craigwilliamsmusic wrote:Mid Tom -
Do you have same sound if you switch between Maracas and Handclap ? Check GND on this section.craigwilliamsmusic wrote:Maracas/Handclap
Ok thank you. Ill go through these and report back.
Hi Craig,
I compiled a list of strategies for troubleshooting DIY-Problems on my Yocto Blog:
http://tr-bob.tumblr.com/
With a bunch of links and quotes from more experienced users:
http://tr-bob.tumblr.com/post/824683952 ... leshooting
First of all: don't despair. When something goes wrong, you learn! and that's why you went DIY in the first place, right? so it's working!
You'll get there - I never seriously thought I would when I unpacked the Yocto and all its 1500 parts...!
Enjoy!
Enjoy!
Thank you for getting back to me so fast. I'm just going to try and knock these problems off one by one.
Are you talking about the ground wire from the IO board to the Main Board?e-licktronic wrote:Dear Craigwiliamsmusic,
Yes its all the sounds.e-licktronic wrote:2.It's a problem with the common trig. Which instruments are 16th played? all instruments ?
Ok I just checked the bass drum parts. R169 is 41.5K rather than 47K and U12 is now showing -14.36V and +14.39.e-licktronic wrote:3. Check R164, R168, R169, C43, VR6 value. Is U12 right powered ?
Dear,
Download full schematic and check GND all on your boards with Ground Pad as reference.
Do the same thing on the IO boards.
Ok so I have been going through this thing like crazy. I changed out that resistor but the kick still sounds the same and I can't find a problem with the ground just yet. I'm still going through the modules. Here are some sounds to show the errors I have been talking about.
I have made some comments so you can hear and see what is going on.
Also the master volume is still very very quiet.
here is the sc link just incase embedding doesn't work
https://soundcloud.com/craigwilliamsmus ... ds/s-TSNK5
Last edited by craigwilliamsmusic on Apr 21st, '14, 13:49, edited 1 time in total.
Hm, it seems the track is not available to be embedded, only on soundcloud directly.
There seem to be a number of problems. I think the smallest is the cowbell -- there, it seems you only need to tune the two trimpots to 1.85 ms and 1.25 ms pulses respectively (check the documentation in the cymbal section: http://www.e-licktronic.com/en/content/34-cymbal)
Everywhere else I'd advise you to go through the sections, part by part and make sure that *everything* is the correct values. I attached an XLS sheet for the handclap and high tom sections, where you can go through the parts and check them off. I think you don't need high tom -- but I'm hoping someone else might..
I think you should start debugging the kick, because that is pretty self contained, whereas the handclap utilizes opamps in other sections, for example.
hope this helps...! good luck!
- Attachments
- Downloaded 1131 times
- Downloaded 1153 times
thanks Misa i'll keep going through it and see if i can see anything wrong.
Mid tom issue: Could you check with a scope (or sound card scope) trig signal on Q54 emitter when sequencer isn't running and when it does.
Bd issue: Check C43 polarity
Cowbell issue: Need tune
Maracas/clap issue: trim TM3, is it changing the volume of noise source ?
HH issue: Is cymbal working ? could you check noise source on U3 Pin7 with a headphone or/and scope.
Hope it will help us to solve some of your problems
