Kick drum has some noise tail - anyone else and how to correct?
Posted: May 12th, '25, 15:54
by FlavioB
Hi all.
My Nava (with the Extra9+ kit) has some noise tail on the kick drum - I can share the audio if anyone tells me how to upload an audio file here.
Anyone else experienced this and knows how to fix it?
TIA
Re: Kick drum has some noise tail - anyone else and how to correct?
Posted: Jul 8th, '25, 01:43
by lyly19
Hey! Yeah, I’ve run into that issue before with my Nava as well. The noise tail on the kick can sometimes be caused by decay settings that are too long or a grounding issue. You might want to check your kick decay pot and try dialing it back a little to see if that shortens the tail. Also, make sure all your solder joints are clean, especially around the kick circuit and the noise section—sometimes a tiny bridge or cold joint can introduce odd artifacts.
Pokerogue
If you can upload the audio to a service like Dropbox or Google Drive and share the link, I’d be happy to give it a listen and see if it sounds familiar.
Hope that helps!
Posted: Jul 8th, '25, 13:08
by FlavioB
Hi and thanks for your reply.
Here's the audio file -->
https://we.tl/t-BMmug7T8mj
It will be available only for 3 days - if you don't download it by then, let me know privately and I can share it with you in some other way.
Posted: Jul 14th, '25, 04:10
by ugaylord
FlavioB wrote: ↑Jul 8th, '25, 13:08
https://we.tl/t-BMmug7T8mj geometry dash lite
Hello, can you share it for me? Thanks a lot
Posted: Jul 14th, '25, 07:05
by FlavioB
I'm on vacation right now - no access to my data. I'll update this thread by the end of July with the audio slice again.
Posted: Jul 28th, '25, 11:56
by FlavioB
Here again:
https://we.tl/t-QQXxzEM6fN
Available for the next 7 days.
