firmware update problem 1.017 -> 1.0xx
  • I borrowed windows PC, and tried it.
    however, firmware has still been 1.017. I can not update firmware.
    I used MidiOx with setting buffer to 64 byte. I also used SendSX. but these do not help this issue.
    EEprom is Micropchip 24LC1025.
    I don't know what is happen. I suspect that is cause of boot loader.
  • Junk16,
    do you have a ICSP burner to re-burn the bootloader ?
  • I am really eager for a fix for this as well. One of my two Nava's updated successfully but the other would not after dozens of attempts of all different settings and software.
    I have an Arduino Uno R3 which I believe can be used as an I(C)SP. I attempted to follow online directions to use Arduino Uno to burn a new bootloader to the Nava ATMEGA chip on a breadboard, but I couldn't get it to work. I could access the chip but couldn't successfully write anything to it, how to set the fuse bits and accomplish this is not very clear.
    Your help would be very appreciated e-licktronic! Please help..
  • e-licktronic
    unfortunately, I don't have ICSP burner. but I found holes are described ICSP on nava main board, these are useful?
    and I have Arduino Duemilanove, but this old one would work fine or not with ArduinoISP I don't know.
    if using ArduinoISP, I should operate like following topic?
    viewtopic.php?f=17&t=436
    and which boot loader do I take? mighty-1284p?
    https://github.com/maniacbug/mighty-1284p
    please help.
    regards.
  • Dear,
    To burn the bootloader in your atmega1284p follow this instruction (only on Window):
    -Open Arduino IDE and open the sketch "ArduinoISP" (file > example > ArduinoISP)
    -Select the right serial port and Board then burn this sketch in your Arduino Board.
    -Connect the Arduino ICSP connector to the Nava MainBoard ICSP connector (+5v to +5V, MISO to MISO...). You have to connect Nava ICSP RST pin to the Arduino digital pin 10. Do not connect Nava power supply !
    More information about how to use Arduino as an ICSP programmer
    -Download the "tools" Rar file provide in this topic
    -Unrar in C:\
    -Open the file "Nava_V1_020_All" in a text editor (notepad++ or others)
    -By default the serial port is "COM4" but maybe yours is different. Write your serial port number on each line and save the file
    -Now double click on the Nava_V1_020_All.bat file, a windows command window will open with the statue of burning process.
    -Wait until the end
    That's it ;)
    tools.rar (485.16 KiB)
    Downloaded 6051 times
  • can I use AVRISP mkII directly to the ICSP on the nava board?
    http://www.atmel.com/tools/AVRISPMKII.aspx
    I'm Totally new to this stuff...
  • e-licktronic
    Thank you for your informations!
    I will try it later :D
  • Reggiechacha wrote:can I use AVRISP mkII directly to the ICSP on the nava board?
    Of course you can, maybe you must change the programmer "avrisp" name in the *.bat file by "avrispmk2".
    More information on how to use avrdude
  • I'm still having problems.
    My Nava firmware is 1.018 but also will not update.
    When running the "Nava_v1_020_All.bat" file, avrdude has verification errors during two steps.
    I have an Arduino Uno R3.
    I have it connected to a Windows 7 64bit system, powered by the USB connection. It is set to COM 6.
    Using Arduino IDE 1.0.1, I set "Arduino Uno" as my board, and selected my COM port (6). I loaded "Examples>ArduinoISP" and then selected "Upload".
    My Arduino Uno has two sets of ICSP pins. I connected my Arduino ICSP to the Nava ICSP using the Arduino ICSP pins by the lower edge of the Arduino board. I connected 5v to 5v, MISO to MISO, MOSI to MOSI, GND to GND, and SCK to SCK. I connected Nava's "RST" pin to the digital pin 10 on the Arduino (& nowhere else).
    After connecting the ICSP pins, the Nava LCD and sequencer powers on.
    I unzipped the "Tools" file (to "c:\tools..), and edited the .bat file to reference my Arduino's com port. I then ran the .bat file, but it failed -- I had to add libusb0.dll (from the Arduino IDE folder) to the "tools" folder in order to get avrdude to function.
    After adding the libusb0.dll file to the "c:\tools" folder, I ran the edited .bat file and avrdude gives me results.
    The first step (lock data) fails verification. It also fails the verification of the Nava_v1_020.hex file. The other steps verify successfully.
    Any help or further instructions very much appreciated...
    C:\tools>C:\tools\bin\avrdude.exe -c avrisp -p m1284p -P COM6 -b 19200 -u -e -U
    lock:w:0x3F:m -v
    avrdude.exe: Version 6.1, compiled on Mar 13 2014 at 00:09:49
    Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
    Copyright (c) 2007-2014 Joerg Wunsch
    System wide configuration file is "C:\tools\bin\avrdude.conf"
    Using Port : COM6
    Using Programmer : avrisp
    Overriding Baud Rate : 19200
    AVR Part : ATmega1284P
    Chip Erase delay : 55000 us
    PAGEL : PD7
    BS2 : PA0
    RESET disposition : dedicated
    RETRY pulse : SCK
    serial program mode : yes
    parallel program mode : yes
    Timeout : 200
    StabDelay : 100
    CmdexeDelay : 25
    SyncLoops : 32
    ByteDelay : 0
    PollIndex : 3
    PollValue : 0x53
    Memory Detail :
    Block Poll Page
    Polled
    Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW
    MaxW ReadBack
    eeprom 65 10 128 0 no 4096 8 0 9000
    9000 0xff 0xff
    flash 65 10 256 0 yes 131072 256 512 4500
    4500 0xff 0xff
    lock 0 0 0 0 no 1 0 0 9000
    9000 0x00 0x00
    lfuse 0 0 0 0 no 1 0 0 9000
    9000 0x00 0x00
    hfuse 0 0 0 0 no 1 0 0 9000
    9000 0x00 0x00
    efuse 0 0 0 0 no 1 0 0 9000
    9000 0x00 0x00
    signature 0 0 0 0 no 3 0 0 0
    0 0x00 0x00
    calibration 0 0 0 0 no 1 0 0 0
    0 0x00 0x00
    Programmer Type : STK500
    Description : Atmel AVR ISP
    Hardware Version: 2
    Firmware Version: 1.18
    Topcard : Unknown
    Vtarget : 0.0 V
    Varef : 0.0 V
    Oscillator : Off
    SCK period : 0.1 us
    avrdude.exe: AVR device initialized and ready to accept instructions
    Reading | ################################################## | 100% 0.11s
    avrdude.exe: Device signature = 0x1e9705
    avrdude.exe: erasing chip
    avrdude.exe: reading input file "0x3F"
    avrdude.exe: writing lock (1 bytes):
    Writing | | 0% 0.00s ***faile
    d;
    Writing | ################################################## | 100% 0.16s
    avrdude.exe: 1 bytes of lock written
    avrdude.exe: verifying lock memory against 0x3F:
    avrdude.exe: load data lock data from input file 0x3F:
    avrdude.exe: input file 0x3F contains 1 bytes
    avrdude.exe: reading on-chip lock data:
    Reading | ################################################## | 100% 0.02s
    avrdude.exe: verifying ...
    avrdude.exe: verification error, first mismatch at byte 0x0000
    0x0f != 0x3f
    avrdude.exe: verification error; content mismatch
