Soooo I'm, getting triggers from pin 1 of IC5 as expected for the kick drum, bit I'm testing continuity from there to R155 which there should be, I think, but there is none...
EDIT: I was thinking that 'TRIG' on the schematic was trigger in, where in fact it is BD which is the trigger in..
Soo... Base on Q39 shows a pulse on the scope as I would expect from the active steps, but I can't find anything similar on Q40, the base of that seems to be the accent trigger, which is consistent with the parts that are working..
What to try next?
It's weird that it is the part which are all controlled by IC5 that are not working, but I used a wire to send the BD trig to the cymbal and the cymbal triggered on the active BD steps, as expected, so it seems that IC5 is working as it should...
