Page 1 of 2
Build tips
Posted: Jul 30th, '14, 18:55
by Snoozr
I thought it would be nice to start a "tips" thread for new builds. Here's my tip. Instead of following the instructions exactly, you might want to try stuffing two instruments' worth of resistors first. This way the soldering is a little bit more spaced out instead of so tight, and I found I could move a littler faster this way.
Once the resistors are in, you can then fill in the rest for those two instruments, solder, and do your voltage checks for both at the same time.
Anyone else want to share?
Re: Build tips
Posted: Jul 31st, '14, 13:09
by ElSchtroumpf
I used precision sockets for all the ICs, including the BA6110. Also, I noticed it is best to remove the nut from the two rotary switches, since they are too high.
As pointed out in a few other posts, take your time, be organized and systematic, and don't try to cut corners or make the work easier. It took me 4 weeks, including sorting all the components, to finish the soldering. I sorted 2 sections a day, and soldered one section a day, or until I felt my concentration was fading. I made some mistakes along the way, mostly a few resistors that were in the wrong place, but since all the sections were sorted, these mistakes showed up as I was working on them. In the end I had only soldered one IC socket the wrong way in the sequencer section, so the IC was in the wrong way as well. Popped it out, put it back in the right way, and everything worked fine.
And of course, use decent tools. I bought a DMM and a USB oscilloscope for this project, as well as eutectic solder. These are good long term investments if you plan on doing more electronic work/DIY kits/old analog machine maintenance.
Re: Build tips
Posted: Aug 1st, '14, 18:11
by synthdood
Great tips so far. This is a daunting project to assemble and there are lots of areas where you can make mistakes, but there are a few things you can do to catch them as you go. As suggested, buy IC sockets for all the IC's. There are 19 = 8 pin sockets, 3 = 14 pin sockets, 7 = 16 pin sockets. You can buy these dirt cheap on ebay from Chinese sellers. Don't buy them from Mouser they are way too expensive there.
Work on one sound section at a time. I like to place all caps in first. Place all the caps without soldering them in. If you place a part where it should not go, you will discover that you made a mistake when you get to the parts that is supposed to go in there, and you can swap out with the correct one. After you have finished placing all the caps you can solder them in. When you finish you can cut all the leads off. Next move onto the transistors, then resistors.
I like to use organic lead solder. I like it because after you are done soldering you can wash off the acid based flux with warm soapy water and a plastic scrub brush. Use the brush on the bottom side only! The component side can just be washed off gently with a soft paint brush or just with water. After that rinse the entire board with filtered water so there is no mineral residue from the tap water. Dry it out by placing it in the sun for a little while. Solder in the caps, transistors, and resistors first, then wash the board.
Only use organic solder on, caps, transistors, resistors, and diodes. I also use it on Electro caps, because they are sealed with a rubber grommet at the bottom, but if washing them makes you nervous, you can place them last and use regular non washable rosin solder on them. Use regular rosin based lead solder on all other parts that cannot get wet like the sockets, pots, switches, trimmers, jacks, and wires. Don't get IC's wet either. These are the parts that should be placed last. This way you will end up with a set of boards that look nice and clean. Make sure the board is dry before soldering anything in again.
I don't like lead free solder because it requires higher temps and it's harder to work with. I like to work on one or two drum sounds per day if I can. So far it is taking a lot longer than I expected to build this so don't rush.
Ok that's it for now. If I come up with other tips I will write them down.
Re: Build tips
Posted: Aug 4th, '14, 10:48
by rv0
synthdood wrote:As suggested, buy IC sockets for all the IC's. There are 19 = 8 pin sockets, 3 = 14 pin sockets, 7 = 16 pin sockets. You can buy these dirt cheap on ebay from Chinese sellers. Don't buy them from Mouser they are way too expensive there.
I feel obliged to comment on this.
although IC feet are recommend by a lot of people, and thus common in the DIY scene, keep in mind that IC feet greatly reduce the reliability of the device. Especially when the device is transported a lot for live usage;.. IC's may just pop out
The cheap kind of sockets are _cheap_ and prone to breaking easily.
A lot of old computers (e.g. Apple IIe) have their RAM ic's soldered directly to the main board. there's a good reason for that
My advice for anyone who wants to build a really reliable unit:
buy professional IC sockets for the CPU and Eeprom. (round machined pin sockets). Solder all other IC's direct to board (but triple check orientation)
Re: Build tips
Posted: Sep 11th, '25, 10:18
by jassybella
Visit
yt.be/activate to sign in and link YouTube on your smart TV, console, or streaming device in minutes. Go to
yt.be/activate, enter the TV code, and connect your device to your YouTube account instantly. Activate YouTube on smart TVs and consoles easily at
yt.be/activate with your device code. Link your YouTube account to TV or console quickly by visiting
yt.be/activate website. Access YouTube on any device by entering the code at
yt.be/activate for fast activation.
Re: Build tips
Posted: Sep 11th, '25, 10:25
by jassybella
Use
yt.be/activate to pair your smart TV with YouTube and enjoy unlimited streaming. Visit
yt.be/activate to activate YouTube on Roku, PlayStation, Xbox, and smart TVs. Enter your activation code at
yt.be/activate to sign in to YouTube on TV devices. Quickly connect YouTube on smart TVs by using
yt.be/activate for activation. Go to
yt.be/activate to activate YouTube on consoles, Fire Stick, and streaming boxes.
Re: Build tips
Posted: Sep 11th, '25, 10:30
by jassybella
Pair your YouTube account with any device easily at
yt.be/activate. Enter the unique TV code at
yt.be/activate and start watching YouTube on big screens.
Yt.be/activate lets you activate YouTube quickly on smart TVs and consoles. Securely activate YouTube by visiting
yt.be/activate and entering your TV code. Watch YouTube on your smart TV by linking it to your account at
yt.be/activate this website.
Re: Build tips
Posted: Sep 11th, '25, 10:34
by jassybella
Activation guide: Use
yt.be/activate to connect YouTube to your TV or device.
yt.be/activate makes it easy to sign in and stream YouTube on large screen devices. Visit
yt.be/activate to activate YouTube on devices like Roku, Xbox, and Fire TV. Activate YouTube in just a few steps at
yt.be/activate with your device’s code. Go to
yt.be/activate to set up YouTube access on your smart TV or console.
Re: Build tips
Posted: Sep 11th, '25, 10:35
by jassybella
Link your YouTube account to your device online via
yt.be/activate. Simple steps at
yt.be/activate help you activate YouTube on any streaming device. Enjoy YouTube on your TV by entering the code shown on-screen at
yt.be/activate.
Re: Build tips
by jassybella
Visit
discover.com/activate to quickly activate your Discover credit card online and start using it today. Go to
discover.com/activate and follow the steps to securely activate your Discover card. Easily activate your new Discover credit card online at
discover.com/activate in minutes. Access
discover.com/activate to set up your Discover card and enjoy seamless banking. Activate your Discover credit card safely by visiting
discover.com/activate this website.
