Nava v1.2 - How to disable mixer? (SOLVED)
Posted: Sep 2nd, '20, 08:30
I'm testing my first nava and I get a nasty noise from the mixer/master part. I use only individual outputs, so i decided to disconnect J14 and debug this part later.
I solved the noise issue, but all voices channels are mixed on each individual voice output (i.e.: on the BD i get all the other signals at lower levels).
After a look at 909 service manual, I decided isolate each output from the mixer by removing:
- R501 & 502 on the BD voice
- R504 & R505 on the SD voice
- R528 & R529 on the IDE voice
I still have the same issue, all active voices channels are mixed on each individual output. I don't understand how it is physically possible?
Thanks for your help!
Regards,
Nicolas
Regards,
Nicolas
