				Open High Hat- intermittent fault, no decay and short crunch
				Posted: Jun 20th, '20, 09:59
				by seven
				I've got an intermittent fault with Yocto V1 with the open High Hat having no decay when turning knob and just a crunchy corrupt burst of sound with just attack sounding fine, then it fixes itself to correct and later fault returns.
I've sent it to tech and he cannot replicate it(now working Again), but I fear if not fixed the problem will return after I get it back, any idea of this fault, something starting to degrade or bad connection?
Thanks..
				Re: Open High Hat- intermittent fault, no decay and short cr
				Posted: Jul 19th, '20, 17:12
				by helectromagneticus
				This sounds like a bad connection to me. It's not fun, but I think you'll have to go over the circuit very carefully checking for cold solder joints, cracks, etc. Good luck! I hope you fix it! This type of problem is frustrating I know, but nearly impossible to debug over the internet...
				Posted: Feb 27th, '23, 07:46
				by urderbuttermilk
				There is a problem with Yocto V1 that causes the open High Hat to have no decay while rotating the knob. Instead, there is a crunchy, corrupt blast of sound, and the attack sounds perfectly normal. Sometimes the problem corrects itself, but then it starts happening again later. I have already given it to a technician, and he is unable to replicate the issue (although it is currently working again). However, I am concerned that if the issue is not fixed, it will reappear after I receive it back. Do you have any idea what the issue could be—perhaps a bad connection or something that is starting to deteriorate?
 drift hunters
				Re: Open High Hat- intermittent fault, no decay and short crunch
				Posted: Aug 9th, '23, 01:47
				by radiantdisorder
				I'm having a similar problem, I think you should check the circuit very carefully for cold solder joints, cracks. It seems annoying. Hope to fix it with you soon.
eggy car
				Posted: Aug 21st, '25, 01:42
				by Keira Knightley
				Sounds like a frustrating intermittent issue! Could be a dodgy potentiometer connection on the High Hat decay control. Given it's intermittent, maybe try gently jiggling the knob while playing to see if that triggers it. It might be a dry joint on the PCB too. While waiting, try some
Uno Online  to relax from the stress. Hopefully, you can get it sorted!
